SOURCE: Just a question on specs for Aiwa NSX-5200 system
Hello I have had a look on the internet and found this for you it should let you download the user manual for free, good luck you should find out your specs
www.devicemanuals.com/company/AIWA-manuals-page9.html - 49k -
djdizzys
SOURCE: i have an aiwa nsx 5200 mini system the cd player broke
Soooooooo many people have complained about this system not reading discs properly, yet the solution is incredibly simple. All you need to do is calibrate the lens, and you can do this without even opening the stereo! Here's how:
With the stereo all unplugged, turn it around so the back is facing you.
Now use a flashlight and, looking through the grating on the back, approximate where you think the cd lens mechanism would be. You should see 2 8-pin connector wires side by side (one red and one white) and to their right a small black circle screw type thing.
Using a screw driver, turn the screw thing about 1/10 of a revolution clockwise.
Plug in, and test with a clean cd. If nothing happened, repeat the procedure turning the screw thing in tiny increments (don't over do it.) Eventually, the cd player should recognise the cd. Keep fine tuning and testing until you've found the "sweet spot" where it recognizes and plays cds optimally.
Overall, you should NOT have to turn any more than a full revolution, and even half a revolution is pushing it. What you are really doing by turning this screw is fine tuning the "data reading point" of the laser. Too close and it will focus on the area between the cd and the lens, causing failure to recognize the disc. Too far and it will focus past the data perhaps recognizing the disc but not being able to read it. I believe the major problem with these players is that as they settle in, the area between the lens and cd changes. This would cause a gradual degrading in performance until the player finally failed to recognise any data at all (which is exactly how mine went personally.) There isnt a problem with the quality of the lens itself, therefore it is very fixable!
I have heard that all 3cd Aiwa Mini-systems share this problem so, as long as the calibration tuning screw is exposed through the grating on the back, this fix should work for any of the Aiwa mini-systems with this particular problem. If the screw isnt exposed, it is still possible to get at by opening and dismantling the player. (Unfortunately, i did not originally notice that the screw was accesible through the grating, so i went about pulling the entire system apart and wasting hours of my life. You can thank me later for saving you this tedious trouble as you're listening to cds on your newly fixed player ;-) )
If this doesn't work, or doesn't fix the problem completely, try cleaning the lens. You can do this by either by using a cd lens cleaner (looks like a cd with a brush built into it) or opening up the stereo and using a soft cloth on the lens. You may also want to try putting the screw back to its starting point and using the same procedure but turning the screw counter-clockwise. (I personally had to turn clockwise but who knows, maybe your player settled in differently.)
As for the mechanism itself, i have no idea. I did notice, however, that the lifting mechanism sometimes picks the cd up off-centered causing failure to play. You can semi-fix this by holding the stereo at an angle while it picks up the cd or placing it off-centered in the tray. Its annoying, but it works :)
SOURCE: Liftmaster mod 1245R (1999) has indicator light
If your door is in the open position and the trolley is jammed against the bolt just in front of the motor unit you need to remove the bolt and then run the opener until the door closes. While the door is closed locate the 'up limit control' on the side of the motor unit and turn the control a couple complete turns in the opposite direction of the arrow printed on the cover.
SOURCE: Aiwa NSX-V70 Cassette deck Belt?
u can get from ebay.de website many type belts for sepcaly aiwa nsx seriess,all total cost 25 euro
SOURCE: aiwa nsx-999 display and cd changer problems
I had a similar problem with my NSX-999. For CD, u need to clean the laser or buy a new cd-laser pickup KSS-210A.
For dim display, replace capacitor C107 and C108 in the mainboard if u know how or take to a repair shop and ask them to replace those two capacitors. It soled my problem
