Televison & Video Logo
Jeremiah Bitrus Posted on Feb 14, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Whats ltt? a jvc
Level 3:
Top Expert:
  • JVC Master 76,851 Answers
  • Posted on May 30, 2019
JVC Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15008207
Points
237762
Thats it.
A JVC.
What else?
Turning on hp slate 500 without power switch
I hope you found a solution months ago, but just in case:
My switch also broke a while back, and this is a common problem with the slate 500 due to the construction of the switch.
This should help:
http://forum.tabletpcreview.com/hp-slate/41309-my-power-switch-just-broke-2.html
My solution: remove what's left of the plastic switch (if anything) then use a long thin thing (LTT) (about 2 cm long) in the hole where the switch was. I use a squashed paper clip - someone else had a mini screwdriver, someone else the toothpick on their pen knife.
Put the LTT straight at the top of the switch hole and pull down, the same way you used to pull down on the power switch, then let go. The indicator light under the switch hole will blink 3 times quickly if you've successfully tripped the switch.
All the best!
Error 4074 Can this be repaired?
You can download LTT from www.hp.com/support/tapetools
Run LTT DDS drive assesment test if it passes then the problem is dpe if it fails the drive needs to be replaced.
Please I did not find what I was looking for. My problem is that My HP Ultrium 448 Tape Drive has stop working. So I opend the Tape Drive and I found out that the tape has teared and I don't know where...
Stop your backup services and Ran some test
First try to double check your SCSI controller drivers and your drive firmware (With LTT)
Tape drive HP LTO-3 (storage works ultrium 960) repair
stop all the backup services services and perform a test
2helpful
2answers
All lights flashing
You need to update the firmware with LTT
TAPE WON'T LOAD
Stop all the backup services.
Run LTT firmware update and some test
1helpful
Blinking Front LEDs
It sounds like the drive is getting confused
Check all cables and try new ones if possible as well as the terminator.
Again try and make it the only device on the bus if you can.
Try upgrading the firmware with the hp ltt program
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=406731&lang=en&cc=us&taskId=135&prodTypeId=12169&prodSeriesId=406729
After that you could also try a cleaning tape and a new data tape for an lto test in ltt.
Failing that i think you need to send it for repair
www.tape-drive-repair.com
Tape-Techie
Top JVC Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
 Grubhead
Grubhead
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
