SOURCE: My Bissell Proheat is not spraying water. What is ...
It is very simple and inexpensive to fix. All you need to do is replace the pump belt. Here is the belt you need:
Bissell Proheat Pump Belt
SOURCE: I have a bissell proheat 2x and it leaks water
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
SOURCE: The bissell proheat turbo carpet cleaner is not sucking up water.
heatman101
jer
SOURCE: Bissell Proheat 2x TurboDoes not pick up the water after cleaning
heatman101
m,nb
SOURCE: bissell proheat 2x pet won't spray water or ****
A belt may have broken, there are two which drive the rollers. Remove tank, turn over and have a look behind the brushes. Check the manual for how to find and replace.
Here
Bissell
Bissell
heatman101
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
heatman101
