Hello Joe Williams,
Just a casual look ... it would seem to be an
assembly for your FEATHERWEIGHT...
A real model number would allow for more
than a guess... (what the heck):
eBay search seems to show a VERY REASONABLY
priced wheel assembly...
https://www.ebay.com/sch/i.html?_from=R40&_trksid=m570.l1313&_nkw=dirt+devil+featherweight+wheel&_sacat=0&LH_TitleDesc=0&_odkw=dirt+devil+wheel
Look VERY closely...
to see how to pry off the wheel cover
(( and remember the screw-driver may
look like a "PHILLIPS" but is more likely
the "REED and PRINCE" (has 45-degree flukes
and a sharper, pointed end).
Makes life a lot EASIER:
CERTAINLY a worthy expense (valued tool).
Hope this helps...!
SOURCE: Dirt Devil vacuum
You might unhook the belt, if it still sounds real loud, then the motor is bad and will have to replaced.
SOURCE: Dirt Devil Extreme Quick Vac - Won't turn on
Check that the filters are completely clear and not blocked - especially the top filter on top of the bin assembly. If its clogged completely brush it free of dirt and then reassemble. Make sure the inner cone filter and mesh filter is also completely clean. Then check the hose and main dust channel - something is clogged that makes this machine overheat and stop working - and often with this model (Hoover also make it in the UK under the Alyx name) its down to clogged filters or small clogs of dust in the dust channels.
Don't forget to rate, thanks.
SOURCE: No suction
take the cone filter out of the dirt cup and start it up if you have suction the filter is the problem,if still no suction the you have a clogged hose or a clogged intake hose which is at the bottom it will be a clear hose coming up the backside from the bottom
SOURCE: Dirt Devil vacuum M85845 broken belts. Can't get
call all-type vacuum &janitorial supply.lisa can help you.314-275-8006
SOURCE: dirt devile featherlite vacuum pushes extremely hard on high pile carpeting
the dirt devil featherlight has a automatic height adjustment for carpet and bare floors.check the wheels and see if there is something wrapped up around the wheels
