Ignore Nate Archibals - FIXYA famous spammer
Website https://big-manuals.com/products/ford-escape-2000-2007-workshop-service-manual
helped me repair it within an hour, all by myself!!!! It's amazing, no hassle at all
From wiring diagrams, schematic illustrations, spark plugs info, parts info, chassis number, valvetime settings, step wise instructions, torque specs, error/fault codes, engine info, to every single minute parts, you get everything in there you can't imagine how detailed it is
SOURCE: 03 ford escape v6 find & change spark plugs
i also have a ford escape. the other three plugs are under the upper intake manifold. You have to remove this to change them takes about an hour in a half if you have some experiance working on cars
SOURCE: 2005 ford escape 3.0l AWD XLT - DRIVESHAFT CARRIER
if there is some one in your area that balances driveshafts they can change just the bearing for you
SOURCE: 2002 Ford Escape V6 XLT, problem w/ initial start in cold weather
Does the engine crank but just not start? Or... are you cycling the ignition switch without trying to crank the engine? Based on the information you have given, I would first guess that the fuel pump may be going out. I say this because when you first turn the key on the pump primes the engine with pressurized fuel. If the pump is getting old, it may take a few power cycles to get it going. You can test this theory by having somebody listen near the rear of the car while you turn the key on for the first time. The fuel pump make a faint, yet distinctive high pitch noise that can be heard when you turn the key on. Try that first. Next thing you would try is checking the relays for proper function... starting with the fuel pump relay. Good luck.
SOURCE: 2002 ford explorer xlt 4x4... Vehicle won't start
My 2002 Ford Explorer have the same problem
