Washing Machines Logo
C
Chuck Posted on Aug 02, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
.l have whirlpool washer my temperature dail is not working right
Carmen Mikulic
Level 2:
Sergeant:
  • Expert 415 Answers
  • Posted on Aug 02, 2018
Carmen Mikulic
Expert
Level 2:
Sergeant:
Answers
415
Questions
0
Helped
217640
Points
909
Hello there,
Is it a front loading or a top loading machine? Check the knob and if the knob is ok, then it’s yhe switch behind it.
What is the acuwash sensor
Washer temperature sensors and water level settings
The temperature of your washer's water varies with your laundry care needs. Standard washer models typically feature three temperature settings: Hot/Cold, Warm/Cold, and Cold/Cold—and higher-end models often offer as many as six or seven temperature settings. Temperature plays a key role in the effectiveness of your detergent—pairing the right detergent with the right setting for your fabrics and soil is important, as this will help reduce damage, prevent detergent residue, and provide the best wash across fabric types. For the best fabric care, look for washing machines with automatic temperature control (ATC). A sensor will control water temperature and ensure cold washes are above 60 degrees (F) to dissolve detergents, and warm washes do not exceed 93 degrees (F) to help prevent shrinking and bleeding.
The amount of water you use for each load also affects washer performance. Doing laundry is a bit like a science project. You need to make sure you are using the right volume of water, with the proper amount of detergent based on the dirt level of the laundry being cleaned. Too much of one component can result in a less-than-perfect outcome. Standard washing machines allow you to select water levels for different size loads, but some models offer more water-level options. Washers with automatic water levels use sensors to determine load size and adjust water level for best cleaning and rinsing performance. You will generally find these options in higher-priced top-loading washers. A benefit of front-loading washing machines is that most come with this automatic water-leveling feature.
Whirlpool® AccuWash™ temperature control sensor provides a temperature-controlled wash.
this is an article from the whirpool website, u can get a manual printed or downloaded by going to whirlpool.com and going to owners center and typing in ur model number.......
I HAVE A WHIRLPOOL WASHER GHW9150PW3 FRONT LOAD WASHER AND THE CODE F 05 IS BLINKING
If during the water heating step in the wash cycle, the water
temperature sensor (NTC) value is out of range, the “F/05” error code
will be displayed.
1. Unplug washer or disconnect power.
2. Check the water temperature sensor. Refer to the
“Water Temperature Sensor” section. Check
connections to the water temperature sensor.
3. Check resistance of heating element, if present on this
model. (abnormal = infinity)
Or just call service! (:
MY WASHER DOESNT SPIN OUT YOU HAVE TO KEEP GOING IN THERE TO ADJUST THE CLOTHES TO MAKE IT SPIN
i am assuming this is a top load. if so place a screw driver in the lid switch button, turn dail to spin and while holding the spin basket in place turn on. is it very easy to hold basket from spinnihg? if so you may have a slipping clutch. to replace, remove washer body by removing 2 screws from timer console. they may be in front or behind. remove body clips located under timer console and lift off body. next remove agitator. next remove 3 , 1/2 inch bolts at bottom of transmission. slide out. clucth is right there on top side of transmisson. part # 285785
can be purchased at repairclinic.com
Maytag washer/hot and cold water
Some whirlpool washers have had A similar problem. They had a intermittent water temperature switch issue. Sometimes they put hot water in when cold was selected. This is probably the same problem as yours. I would replace the water temp switch.
Will only work on cycle, will not agitate in the other cycles
Thanks for your question You say it works on one cycle but not the other lets sat you start a regular wash ,the washer should fill ,wash for the minutes you have set, pump out the water #spin , Stop fills & rinse stop pump out water &spin If you try a delicate cycle and it does not do what it did on regular cycle . You have a timer problem . Thanks for your question hope i helped you solve it . THE APPLIANCE DOC
F-23 error code
HOW TO FIX WHIRLPOOL WASHER F23 ERROR CODE What does F23 mean on whirlpool washer? It means there is a heater failure. If the water temperature in the washer fails to reach 86 degrees or higher then the washer will give the F23 error code. To fix the whirlpool washer f23 error follow the steps listed below.
Note: Some models do not have a heater as shown below, some models just have a temperature sensor. If your model does not have a heater just skip to checking the temperature sensor.
  1. First unplug the washer.
  2. Check the wiring to the heating element make sure its not burned, broken or corroded.
  3. Check the heating element for continuity of course if it does not have continuity then replace the element.
  4. Check the water temperature sensor wiring for corrosion or breaks.
  5. Remove the wiring harness from the temperature sensor and measure the resistance of the sensor. Refer to the chart below and if its out of range replace the sensor.
see link below for details and where to buy the part which is under $80 and fairly easy to replace
How To Fix Whirlpool Washer F23 Error Code Appliance Repair Guides
2helpful
3answers
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
