Recently I had an odor problem with the Airxcel 48000 Model 48254A876. The unit had been sitting unused for a long time. The odor issue was resolved by using coil cleaner but afterward the unit started leaking water inside the RV after being turned off and then also during use. Is this a gasket issue? the drain hole is functioning properly. Please assist
SOURCE: Whirlpool Cabrio Washer- When draining, water leaks out of hole
probably rubber hose from tub to pump broke, access from back or bottom, (cabrios are open bottom) pump in rear. there is a recent bulletin about tub ring not channeling water from dispenser completely into tub
SOURCE: rv air conditioner leaking
I have the same problem....it is a negative pressure problem holding water inside the unit until it overflows the pan and runs into the duct system. why this occurs....I don't know....I cant find a problem with my air return, but as soon as you turn in off, the water comes gushing out the drains on the unit. I resolved this....temporarily....by twisting up a paper towel into a wick, and placing one end up into the drain tray, with the other end lying well out into the exterior case. This lets the water wick out and keeps the tray drained. I don't understand the problem and don't know what the permanent fix will be, except maybe cutting a hole and placing an intake vent directly below the unit.
SOURCE: 2007 H3 sunroof leak
The ramp up mechinism is not closeing the gasket up tight agaisnt the sealing surface so this is a warrenty issue, take it in and have it repaired by the dealer. If you want asstanice to do it yourself please Post here for detailed instructions on doing it yourself. You would do better in a chat because of the problems you may run into that way you work with just one person. Hope this helps.
SOURCE: Intertherm Air Handler Coil leaking water
replace it it's junk - going to do that this time because this is the fourth year of the same problem on the hottest days this intertherm junk downflow ac unit condensates where it will not and con not be captured by the pan - built by relatives of the guy who designed the titanic -
