20 Most Recent Comfort-Aire RADS-51 Air Conditioner Questions & Answers
Comfort-Aire R Series RADS-151Q Window Air Conditioner. How to take a fan out of it please?
Take it out of the window and remove all the case screws. Or better still take it to a local AC company and give them the headache and also get them to service it and topped up with gas. https://www.google.com/search?q=Comfort-Aire+151Q+Air+Conditioner https://www.google.com/search?q=air+conditioner+repair+near+me ..
7/18/2022 12:57:33 AM • Comfort-Aire... • Answered on Jul 18, 2022
I need the fan blade for a Comfort aire model PE121A. The only part number I can find is (20402021300). Does any one carry a replacement fan?
www.alpinehomeair.com. This website stated"please call us for suitable replacement". Might have some luck there? Seems to be a discontinued part, as you may know already. I checked 3 others and all stated the same, discontinued.
8/24/2017 9:07:49 PM • Comfort-Aire... • Answered on Aug 24, 2017
I have a comfort-aire RG-61A window AC. Can it be installed sideways? or only installed horizontally?
Only horizontal. The compressor won't run for long otherwise. The condensate drain would let water inside too.
7/11/2017 5:59:05 AM • Comfort-Aire... • Answered on Jul 11, 2017
Comfort aire R410A
So I'm assuming your house is 1200 to 1500 sqft?? Why is unit freezing?? Is the filter clean, vents open, blower motor running?? What's the Static pressure on the system?? Is there a refrigerant leak?? How about the txv?? First report the installer to the better business bureau, then find a qualified company to fix the unit. Good Luck!! If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
5/9/2017 2:17:00 PM • Comfort-Aire... • Answered on May 09, 2017
What does fault code P0 means?
Magnetic clutch on compressor is probly bad or the whole pump,fuse or wiring .
5/8/2015 4:53:42 PM • Comfort-Aire... • Answered on May 08, 2015
Comfort-Aire REG-183 18,500 BTU Window Air Conditioner & Heater cuts on and off when not set to auto on heat only
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset. Air Bulance AC Cleaning Repair Services
4/12/2015 4:55:28 PM • Comfort-Aire... • Answered on Apr 12, 2015
F2 on display in AC unit
could be the room sensor or pipe sensor got jacked out from the board. check if any loose connections exists.
2/8/2015 3:32:37 AM • Comfort-Aire... • Answered on Feb 08, 2015
How to fix Comfort-aire e1 code
most of the 'e' codes point to the room sensor or pipe sensor being defective.
2/8/2015 3:30:37 AM • Comfort-Aire... • Answered on Feb 08, 2015
Heat elements won't come on
Check your breakers if they off flip them on if it does it again call us no amount of help on here can guide a DIY homeowner in proper diagnostics on this issue your playing with high voltage and your life.
11/26/2014 4:58:48 AM • Comfort-Aire... • Answered on Nov 26, 2014
Comfort-Aire RADS-51 Air Conditioner Logo
1 questions posted
Top Comfort-Aire Heating & Cooling Experts
Marvin
Marvin
Arnie Burke
Arnie Burke
ADMIN Andrew
ADMIN Andrew
Are you a Comfort-Aire Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Comfort-Aire Heating & Cooling
Most Popular Question
water leaking floor from comfort
  • Heating & Cooling
