Televison & Video Logo
B
Ben Lapworth Posted on Jun 11, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hitachi 32HB6J51U no picture; inverter, mainboard or T-con?
Hi there, I've owned a Hitachi 32HB6J51U for about 18 months and all was fine until last night when the screen went black but I could still hear sound. After leaving it unplugged all night it did work momentarily this morning, but after 5 minutes or so the picture was lost again. Since then it does work momentarily after leaving it unplugged for a few hours. I have tried the torch method but I don't seem to be able to see an image on the screen. I've opened up the TV down to the LEDs and they all work when I power up the TV, and I can also see light through the vents at the back when the screen goes black. This leads me to believe the LEDs are fine and there is a problem with one of the boards. It looks as though the TV has a combined PSU and inverter Vestel 17IPS62 and separate main board Vestel 17MB110. There is also what I believe is a t-con connected to the screen at the bottom of the unit. At the moment I am thinking I need to replace the inverter/power supply board but I don't have much experience in repairing TVs and can't be sure. Is there a possibility that the t-con could be causing the problem? Thanks in advance.
Grubhead
Level 3:
  • Hitachi Master 5,755 Answers
  • Posted on Jun 12, 2018
 Grubhead
Hitachi Master
Level 3:
Answers
5755
Questions
Helped
1662732
Points
11417
It does sound to me like the T-Con. If you can change the channels even though you can't see the picture then that's is a T-Con problem. Especially as you can see the lights. Before replacing any of the boards check for bad solder joints and poor connections between the boards, as the TV does sometimes function right.
5 Related Answers
Anonymous
  • Posted on Jul 19, 2007
SOURCE: Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
electroman
  • 1039 Answers
  • Posted on May 02, 2009
SOURCE: KDS-R60XBR1 Sony Projection SXRD
When the tv is working turn it offO on the remote press display,channel 5 number,vol-,pwr quickly in that order. you will see the self check screen. items with a 1 to the right is failure. the remove the slf check screen turn set off.
Anonymous
  • Posted on Oct 21, 2009
SOURCE: new lamp turns on flashes 7 times
just replaced lamp and power light goes green then orange and starts to blink 3 times
Chi Chu
  • 8457 Answers
  • Posted on Jan 13, 2011
SOURCE: My toshiba 42" REGZA 42RV535U
U have sound but no picture?Picture does flashes a few sec?Yes,than those 2 long LCD inverter boards are dead.Tries websites like Shopjimmy.com,Ebay.com to buy those 2 long LCD inverter boards for the replacement.
Anonymous
  • 325 Answers
  • Posted on May 12, 2011
SOURCE: My Visio L32HDTV10A that's 5
I delt with 3 vizios with the same problem. For all three, I had to install an internal cooling fan (server type) and run a 12v adaptor to the exterior of the tv case. Everyone I did this for was ok with this as they always had a power strip or second outlet to power on the fan. The overheating sensor is located on the power supply, but without additional cooling of some type this sensor will trip every time.
I've also recommended that some people put a fan behind the tv while it is in operation (if you can stand the noise).
I wish a had a easier fix for you, but this was the only thing that worked on this type of problem that I've seen many times in the past. Board repairs and replacements would yield the same problem due to the heat being trapped internally.
Thank you and best of luck!
1helpful
Replaced the power supply/backlight inverter board and T-con boards on my Samsung 37" TV Seems worse than before
hi this is usually is a tcon board fault, but it can also be a bad panel, if it's flashing could a mainboard fault thanks
shaun
1helpful
I have a Proscan 47LC55S240V87 tv. Yesterday, I lost the picture. There's a faint glow from the screen and there is sound but nothing else. Being that I owned it for a year and two month, I opened...
hi,
You can suspect three things in you tv for this fault .. One is the Balck light inverter board And the disply driver ( T- con ) Board. You have mensioned that there is back light when the picture become blank. You have to check the same one more time and confirm that the back light is working perfectly. If you seems the backlight is ok then the problem is with t-con board or faulty electrolytic capacitors in the power supply board . you have to check for any faulty budged electrolytic capacitors in the inverter board and in the power supply board. IF found such capacitors replace the same will solve the problem. If there is no such capacitor found then you have to check the T-CON board.
T - con board is one which drives the pixels in the rows and colums of the LCD panel. You will find this T-con board in the bottom middil side of the TV. It will be coverd by a metal case or an aluminium ( to protect from inerfearence). There will be a connection from the mother board to this board And other two connectionsfrom this board will go to the LCD pannel. There is no repair possible with this T-con board. It should replaced as a moudule. Have added the picture of faulty budged electrolytic capacitors how its looks , inverter board and T-con board.
2helpful
Hitachi lcd 26 l26d103 lcd tv has sound, but flashing white screen no picture. on both dvd and tv
Hi:
This problem is due to a inverter board, one or two capacitors on the inverter are going bad, look for caps that are puffy on their tops as they all should be flat, also check the T-Con board for faulty conditions as well, when this board goes bad it causes unusual problems.
I have an Insignia NS-42LCD that gets no audio and no video. The power button acts just like it should if the TV was working (red when off, blue when on). I've replaced 4 capacitors on the power board...
Dead T-CON can cause it to show no pictures also.
Here is the example of 37 Insignia that has no picture due to bad T-CON board:
http://s807.photobucket.com/albums/yy352/budm/INSIGNIA/Insignia%20NS-LCD37HD-09/
Please read my guide to understand how LCD TV works.
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there is some troubleshooting you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: www.interliquidparts.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
1helpful
I have no picture on my hitachi lcd tv sound is fine
It may have lost the 24vdc power supply for the inverter circuits or the inverter boards have gone out.
Please see my basic troubleshooting guide here:
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Sound but no picture
Your mainboard is giving you trouble, go ahead and replace it.
1helpful
Hitachi l42vpo1u no sound through hdmi
HDMI port damaged, mainboard need to be replaced.
But be absolute sure your HDMI port is not working properly, I recommed you try it again with another HDMI cable, you can also try same cable in another TV.
Bye
3answers
My Samsung LN-S4692D
before you give up..call samsung directly, they are very consumer oriented and if it is only a couple months out of warranty you might get them to repair it,, 1 800 samsung
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
