Refrigerators Logo
Ronald Young Posted on Feb 04, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
GE Profile French door not cooling 70degrees - GE Refrigerators
L Vincent Testa
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • GE Master 724 Answers
  • Posted on Feb 04, 2018
L Vincent Testa
GE Master
Level 3:
Renaissance:
Answers
724
Questions
0
Helped
367474
Points
3088
The thermostat allows power to flow through to the compressor, evaporator fan and condenser fan. If the cooling system fans and compressor are running, but the refrigerator or freezer is not cooling correctly check for an airflow or defrost system problem.
in other words is there ice frozen all inside if so unplug and take a hair dryer and melt the ice thouroghly
GE Profile French door not cooling Google Search
5 Related Answers
themackshack
  • 27 Answers
  • Posted on Feb 02, 2008
SOURCE: Digital display is blank in GE Profile fridge
Hi. Its either a bad motherboard or control board. I would check the control board for any obvious signs of damage to the board first. I've seen the control board go blank on the GE side by side and it turned out to be the motherboard. The motherboard is located behind a cover on the back of your refrigerator cabinet. You should have a new motherboard on hand at all times because they fail alot. Be sure to put a surge protector on your refrigerator. Good Luck, Mack
Anonymous
  • Posted on Sep 21, 2008
SOURCE: GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
Techsim
James
  • 59 Answers
  • Posted on Nov 07, 2008
SOURCE: GE French Door handle loose
To tighten the screw the first step is to remove the handle. With this model just pull straight up on the handle. It can take a little force but after it finally unclips it moves up an inch or two then pulls straight out. Good luck!
Sea Breeze
John Tripp
  • 4656 Answers
  • Posted on Nov 15, 2009
SOURCE: GE Profile PSC25 won't cool past 45 degrees
With that model that is a sign that defrost is not happening on time or the beginning of the problem. Temperatures in fresh food compartment above 38 are not safe. Look into the back of the freezer compartment and let me know if you see a frost line buildup. If yes it would be a good idea to manually defrost the freezer so you can remove the rear panel and check the defrost heater and defrost thermostat. It's also important that with this model that the problem be resolved quickly. I can help you if you want. The defrost heater will be easy to see if burned out because it has a glass tube around the heating element. If you replace the defrost heater you should also change the defrost thermostat. Fan motors going bad on that refrigerator seem to always damage the control board and if the board is replaced the the fan motor should also. Let me know if you want me to help you, Thanks, Sea Breeze
Anonymous
  • 5 Answers
  • Posted on Dec 21, 2009
SOURCE: there is a loud knocking noise from inside or the
This is normal. It is the actuators adjusting the temperature between the freezer and the fridge.
1helpful
GE Profile PFS22MISBWW not cooling, power/lights on. LED & Fan off
This is a common problem with the GE Profile. In most cases this is caused by failure of the motherboard. If you would like a manual, part numbers and assistance on how to repair please let me know because the instructions are detailed and a lot to Wright if you are only wanting to know what is wrong. You can find a service manual by going here http://appliance911seabreeze.com/
Ge profile refrigerator not cooling
there is a fan that brings the cool air from the freezer to the fridge. make sure thatit is working and that the vents for it are not blocked or frozen
My Ge profile refrigerator is making a loud fan noise what is causing it?
Ice is built up and hitting the fan...
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
My ge profile PFS22SISBSS FRIDE IS NOT STAYING COOL WHAT COULD BE THE PROBLEM?
heatman101
3helpful
Water build up on inside of fridge door of ge french door fridge
humid air in the house. any time you open the fridge, house air is sucked in. when you close it, the fridge cools the air and moisture from the warm air condenses on any cold surface. also check to see if there is a gap in the seal.
2answers
2answers
Freezer never cools consistently and compressor never goes off
I am posting this for the sake of curiosity. I want to know if it gets resolved.
1helpful
2answers
Thanks
Carol
Top Refrigerators Experts
vince
Johnny 1000
