20 Most Recent GE PDS22LBN Bottom Freezer French Door Refrigerator Questions & Answers
My rangemaster will not produce any ice, ive thrawed it out and refrozen it but still no ice?
if you are not getting any water to the ice maker then you have a problem with the water inlet valve and need to replace it.
6/13/2014 5:13:32 AM • GE PDS22LBN... • Answered on Jun 13, 2014
0answers
0answers
RANGEMASTER FRIDGE /FREEZER WATER FILTER WARNING LIGHT
Hi i have a rangemaster s x s fridge freezer and the ice maker has stopped and now the whole fridge freezer has stopped. its 2 years old and out of warrenty can anyone help please with a suggestions as to whats wrong.
12/1/2013 8:59:07 AM • GE PDS22LBN... • Answered on Dec 01, 2013
0answers
GE Profile PFS22MISBWW not cooling, power/lights on. LED & Fan off
This is a common problem with the GE Profile. In most cases this is caused by failure of the motherboard. If you would like a manual, part numbers and assistance on how to repair please let me know because the instructions are detailed and a lot to Wright if you are only wanting to know what is wrong. You can find a service manual by going here http://appliance911seabreeze.com/
6/13/2013 9:15:45 AM • GE PDS22LBN... • Answered on Jun 13, 2013
The fridge isnt cold but freezer is cold
You might need to have the oxygen added or the compressor replaced. Try switching the mains off for a day and leave all the doors open. This will help the ice build up between the freezer and fridge defrost to allow the cold from the freezer cool the fridge. This a temporary solution and it might give you a month before it builds up again.Mine had the oxygen added and the compressor changed and it was good as new after that.Good luck!
9/4/2012 7:47:25 AM • GE PDS22LBN... • Answered on Sep 04, 2012
Wate light onfront of rangemaster sxs fridgefreezer turned red
After you have changed the filter, select water then hold the select button down and it will go blue again.
4/11/2011 7:37:26 PM • GE PDS22LBN... • Answered on Apr 11, 2011
Where is the defrost timer
Remove the control knobs by pulling them. remove the plastic shield the knobs went through, and your timer is to the right, you'll see a hole to stick you screwdriver in to turn it. There is no control board. You need to remove all shelves in the freezer section, and remove the back in the freezer panel to get access to the evap and heaters. Hope this helps get you in the right direction.
3/15/2011 5:43:06 PM • GE PDS22LBN... • Answered on Mar 15, 2011
3answers
GE Profile model PFS22MISBWW stopped working, panel problem?
Replace the main control board on the back of the refrig . PT# WR55X10656 . It's behind a panel about 10" x 6" .
12/2/2010 8:23:11 PM • GE PDS22LBN... • Answered on Dec 02, 2010
GE PFS22MISBWW is a piece of junk
One doesnt like to hear it but possibly cut your losses and look for a less complicated fridge with minimum electronics.
5/17/2010 5:21:09 PM • GE PDS22LBN... • Answered on May 17, 2010
I need the part # for the icemaker ordered
Now here is the confusing part. If your model number is a GE PDS22LBN the Ice Maker would be part number WR30X10039 for the model number posted above your post. If you have sears model number for the refrigerator it will be like 312.235698 for example. Confirm the model number of the refrigerator and I can tell you the correct Ice Maker part number. Thanks Sea Breeze
2/18/2010 8:10:19 PM • GE PDS22LBN... • Answered on Feb 18, 2010
GE PDS22LBN Bottom Freezer French Door Refrigerator Logo
32 questions posted
Top Refrigerators Experts
vince
Johnny 1000
View Most Popular
GE Refrigerators
  • GE Refrigerators
Most Popular Question
reset temp controls refrigerator freezer
  • Refrigerators
