SOURCE: How to reset Language
When a super NVRAM init is performed, the all-in-one language and telecom country/region settings
are undefined. The user is prompted to set the language and telecom country/region. Until these settings
are defined, the all-in-one will not return to the Ready state.
CAUTION A Super NVRAM init erases all data that is stored in both the unprotected and
protected NVRAM memory.
To perform a super NVRAM init
1. Turn off the all-in-one.
2. Press and hold down the * and 5 buttons.
3. Continue to hold down the buttons while you turn on the all-in-one. Hold the buttons throughout
the entire power-on sequence.
4. When Permanent Storage Init. appears on the control-panel display, release the buttons.
5. When prompted, set the language and telecom country/region.
6. Allow the all-in-one to return to Ready before using it.
SOURCE: language changed
Press Menu, go forward (right arrow) to the 4th option (Maintenance), hit enter, hit left arrow once, and enter. This is the language setting. Select language, press start, select country, press start.
SOURCE: change language on htc touch hd from dutch to
You can either use a cooked ROM or use this very handy app HD_Tweak_0.5.4_English
SOURCE: change dutch language to english language before instalation
i used kaspersky 2010 and it was in russian.. i used to chage the language by pressing ctrl+shift+alt +f12. try it! it works!
SOURCE: i want to change the language dutch to english
i want to change the language dutch to englisah
Thanks to all of you. I found it
