This is La Crosse Technology Model S85814
You are using a wireless system that transmits signals between the outdoor sensor and the indoor receiver. They are not a perfect match. You cannot make adjustments, thus if your lucky, the factory matched up the devices prior to the sale. You may contact Lacrosse for a replacement outdoor temperature device.
SOURCE: very slow wipers
Hi gerry the wipers are eletric what year is it this sound like a wiper spindle seezing up spray oil down behind the wiper arm, try that might just be freeezeing up D
SOURCE: Display is fading
Check the batteries first before trying to tinker with the display. Also check for accumulation of fungus, if any, which can also cause the display to fade..............sodeep
SOURCE: Manual for La cross technology radoi controlled digital watch #wt
Downloaded instructions and working on it.
Thank you.
Bernard W. Goering
SOURCE: It looses time and the radio controlled feature
When the battery is installed the second hand will advance eight seconds (2 seconds per step x 4 steps). The clock is now searching for a signal. For the initial setting it is recommended to stand the clock in an upright position near a window. Within five minutes the clock will either receive the WWVB signal and set itself to the exact time, or it will determine that the signal is not receivable at its current location and time of day. If a signal is not receivable it will fast-forward the hands to the 4, 8, or 12 o'clock position and search for WWVB each hour until a signal is received. If the time is manually set the clock will continue to periodically search for a signal and automatically reset the hands when the signal is received.
