Question about La Crosse Technology Wireless Thermometer WS9007UIT
How do get the outside temp to work. - La Crosse Technology Wireless Thermometer WS9007UIT
Posted by chesdearden on
sbranin
    New Friend:
  • 7 Answers
Bring the outdoor sensor inside. Take batteries out of both the sensor and the main unit. Wait 10 minutes. Put batteries in remote sensor. Then put batteries in main unit. Don't touch any of the buttons for 10 minutes or until the outdoor temperature is displayed. If still not displayed after 10 minutes then try again.
Posted on Jan 23, 2011
No outside temp in de display only - - -in thedisplay i see the room temp. No outside temp. I have checked the outside transmitter end i see the red flash.
my unit tells me to insert fresh batteries into the outside sending unit first. then insert new batteries into the inside receiving unit. after the outside temperature shows up, then can reset my inside unit's time, choose F or C and
switch channels. please try changing channels if your
outside temp doesn't show. you can do both units in the house then put one outside after they work properly.
Mar 29, 2018 | Home
Ambient outside air temp sensor
i may be wrong but that sensor is for the ac not for engine operation and at 113 if its not that hot then the sensor is bad but if its summer its ok,, your engine works with intake air temp
Nov 25, 2013 | 1996 Jeep Cherokee
My 2007 honda accord which was bought a few months ago,the outside temperature gauge has stopped working, also i noticed a week earlier a spot of oil on my driveway which came from the car near the drivers...
the outside temp could be the outside sensor, if you don't worry about knowing the outside temp its no problem, the oil leak is something to look into and repair
Sep 03, 2013 | Honda Accord Cars & Trucks
Springfield precise temp instructions
The outside temp for the inside reading quit working this morning when I went to check the temp.The outside sensor was working fine.
What do I do to get the inside one to work again. The other features were working fine.
Jun 17, 2013 | Computers & Internet
During heating (outside temp. 2 deg C), outside
Get the charge tested, check the sub-cooling across the outdoor coil.
Dec 19, 2009 | Heating & Cooling
Climate control display for Outside temperature
Had the same problem, replaced the ambient air temp sensor in front of the radiator. Cost is like 10-15 bucks. Don't worry if temp doesn't change right away. Took me about 5 miles and then it worked great.
Sep 13, 2009 | 1999 Oldsmobile Intrigue
Outside temp sensor does not work on 1995 olds aurora
You can buy a replacement ambient air temp sensor at an auto parts store for about $10. Its as simple to change as a light bulb and can be found behind your front bumper at the base of the radiator.
Jun 27, 2009 | 1995 Oldsmobile Aurora
La Crosse Technology Wireless Thermometer WS9007UIT Logo
5,785 people viewed this question
Top La Crosse Measuring Tools & Sensors Experts
Marvin
Marvin
Ngoro
Are you a La Crosse Measuring Tool and Sensor Expert? Answer questions, earn points and help others
