Question about La Crosse Measuring Tools & Sensors
Cannot get the outside temp to respond on a WS9047U-IT
Posted by jdandihoyt on
sbranin
    New Friend:
  • 7 Answers
Bring the outdoor sensor indoors. Take the batteries out of the sensor and out of the main unit. Wait 10 minutes. Put the batteries back in the outdoor sensor. Put the batteries back in the main unit. DO NOT PRESS ANY BUTTONS. Wait 10 minutes or until the outdoor temperature shows. Once the temperature shows you may use the buttons to set the clock, etc. If it does not show after 10 minutes, then try again.
Posted on Jan 23, 2011
No outside temp in de display only - - -in thedisplay i see the room temp. No outside temp. I have checked the outside transmitter end i see the red flash.
my unit tells me to insert fresh batteries into the outside sending unit first. then insert new batteries into the inside receiving unit. after the outside temperature shows up, then can reset my inside unit's time, choose F or C and
switch channels. please try changing channels if your
outside temp doesn't show. you can do both units in the house then put one outside after they work properly.
Mar 29, 2018 • Home
Last night at 5:00pm my outside temp was 26. My min temp during the night was 19. My current temp outside is 27. The max temp since last night shows 123. What happened?
I am guessing this is an outside weather temperature thing? Have you checked the batteries of the outside probe? Made sure the "channel" is on the right setting etc?
Heater control
Run self test on heater control head. With the key press off and floor buttons at the same time for 2seconds then release and press auto button for a second.this will put system into self test.if no code all the blend door actuators are ok and I would think vacuum leak from main vacuum, black line going through fire
Outside temp will not stay on
You may have this posted in the wrong product category. Please select another category appropriate to the problem and re-post the problem so the correct expert will see and respond to the question..
This is for car and truck problems related to factory installed systems not add on aftermarket systems.
This post can't be removed or moved, please re-post the question in the correct product category. Thanks
What temp should a/c be in 1995 chev on max
Hard to say.
Under normal conditions, vent temp should be about 20 or 25 degrees less than outside air temp.
So if outside air temp is 90 degrees and the engine is at idle speed, vent temp would be around 65 or 70. On the road the vent temp could be less than 60 degrees.
If outside air temp is 70 degrees vent temp will be around 40 - 50.
7helpful
3answers
Danby kegerator not cooling
I just had the same problem. Mine was outside on the patio and the key pad on the front was the problem. cost me $2.27 plus shipping and it took me 5 minutes to fix call Danby back and wait on the phone for their parts and tell them you need the keypad sticker. Good Luck
My Honeywell TH4210D1005 Thermostat will not respond
well with 62 outside temp and then maybe a little solar gain and body heat you very well could be 5 degrees warmer then outside
Measuring Tools & Sensors Logo
Top La Crosse Measuring Tools & Sensors Experts
Lawrence Oravetz
Ngoro
Are you a La Crosse Measuring Tool and Sensor Expert? Answer questions, earn points and help others
