20 Most Recent La Crosse Technology La Crosse C86234 Wireless Weather Station Questions & Answers
We are having the same issue. How did you get this resolved?
La Crosse... | Answered on Jul 06, 2015
Replace the glass reed switch on the circuit board as it is bad. You must be very careful to orient the replacement switch so that it closes only when the rocker arm is at the vertical position. This will take some work to get right. Use a volt ohm meter and set the Plus lead at the reed switch lead at the top of the board. The meter should show a closed circuit only when the rocker is at the top. Good luck.
La Crosse... | Answered on Jan 16, 2014
The WS-7395U uses the La Crosse TX8U outdoor temperature and humidity sensor. That part has a $49.99 MSRP. It is $46.95 from La Crosse; see http://www.lacrossetechnology.com/tx8/index.php to order the part. Other vendors that I checked do not have the sensor in stock for sale separately.
I hope this helps.
La Crosse... | Answered on Aug 21, 2013
5505E MEASUREMETER BATTERY CHANGE (3V CR-2032)
REMOVE WHEEL AND SHAFT BY GENTLY PULLING AXLE OUT OF UNIT.
DRILL OUT 7 PLASTIC HEADS WITH 3/16 DRILL BIT. (ABOUT 1\8 DEPTH)
SPLIT TWO SIDES OF CASE AND REMOVE HANDLE.
SLIDE OUT CLEAR PLASTIC CONTROL UNIT. PUSH DOWN ON BUTTONS AS YOU REMOVE SO AS NOT TO DAMAGE THEM.
PUSH DOWN SLIGHTLY TOWARD THE CASE ON LOCK TABS WHILE GENTLY PULLING CASE APART. START ON ONE END AND WORK YOUR WAY TO OTHER END. KEEP GASKET INTACT. OPEN CASE.
THERE IS A "Y" SHAPED RETAINER HOLDING IN THE BATTERY. WITH NEEDLE NOSE PLIERS, CAREFULLY SLIGHTLY SQUEEZE THE BOTTOM OF THE "Y" AND PULL UP GENTLY. YOU CAN NOW REMOVE THE BATTERY AND INSTALL THE NEW ONE. PUSH RETAINER DOWN TO LOCK BACK IN.
MAKE SURE GASKET IS IN PLACE AND PUT CASE BACK TOGETHER, MAKING SURE WHEEL ADAPTER IS IN PROPER PLACE. TURN ON AND TEST CONTROL UNIT AND TURN WHEEL ADAPTER TO MAKE SURE UNIT IS WORKING PROPERLY.
SLIDE CONTROL UNIT BACK IN BEING CAREFUL OF THE BUTTONS. RE-ASSEMBLE HANDLE AND PUT THE TWO SIDES OF THE CASE TOGETHER. I USED THREE PIECES OF ELECTRICAL TAPE TO HOLD CASE TOGETHER. ONE ON THE TOP BETWEEN THE TWO HOLES, ONE ON THE BOTTOM JUST ABOVE THE DISPLAY, AND ONE IN THE MIDDLE.
PUT THE PLASTIC PIECE IN THE HOLE AND LINE UP. MAKE SURE BOTH O-RINGS ARE ON THE AXLE SHAFT. GENTLY INSERT AXLE ALL THE WAY IN WHILE ROTATING IF NECESSARY.
I WAS SO HAPPY I HAD IT ALL BACK TOGETHER AND WORKING, I HADN'T TAKEN ANY PICTURES AND I DIDN'T FEEL LIKE TAKING IT ALL APART AGAIN. MIGHT ADD PICTURES LATER IF NEEDED. I HAD BEEN LOOKING FOR YEARS ON HOW TO CHANGE THE BATTERY, AND I FINALLY MADE UP MY MIND THAT I WAS GOING TO DO IT.
JMS 10-20-2020
Measuring Tools... | Answered on Oct 21, 2020
You can try the following: 1# Check the main power cable & make sure it has 110V (Do not run the machine with long extension cable).2# Check all harness connection.3# Check keyboard cable connection on back of control board.4# If all the cable connection is good then you may need to replace the control board.
Measuring Tools... | Answered on Aug 02, 2020
Those are precision devices and require factory check up and calibration at regular intervals. Contact your dealer.
Measuring Tools... | Answered on Aug 01, 2020
La Crosse Technology La Crosse C86234 Wireless Weather Station Logo
Popular Tags
11 questions posted
Top La Crosse Technology Measuring Tools & Sensors Experts
robert
Are you a La Crosse Technology Measuring Tool and Sensor Expert? Answer questions, earn points and help others
View Most Popular
  • La Crosse Technology Measuring Tools & Sensors
Most Popular Question
rain gauge not working
  • Measuring Tools & Sensors
