Question about La Crosse Technology The Weather Channel WS-9662TWC-IT-TBP Wireless
Changed batteries,now weatherstation does not receive outdoor imformation
Posted by roy cross on
Tom Chichester
    Top Expert:
  • La Crosse Te... Master
  • 56,006 Answers
La Crosse is very specific about what you should do and how you should do it for a battery replacement.
Begin by removing all batteries, both outdoor and indoor. Install new batteries in the outdoor unit. Allow the time it takes to get from the outside to the inside for the outside unit to initialize and begin sending data. Install batteries in the indoor unit and observe outdoor temperature. You should see indoor temperature as well. Finally, set the time. This last can be tricky as it seems difficult to set an exact time. I have two different La Crosse receivers connected to one transmitter and the one in front of me now is indicating 70 deg F indoors and 80 deg F outdoors.
Posted on Sep 12, 2016
Outdoor temp doesn't show on my LaCrosse 8349
try changing channels on all sensors and the receiver.. You will have to go through a wait time as before. This worked for me last year, but mine eventually failed completely this year
Jun 14, 2017 | Measuring Tools & Sensors
Model WS9611UN-IT - I am unable to receive the outdoor temperature. I have changed the batteries on the outside remote but I still do not receive the outdoor temperature. How can this be corrected
Remove all batteries, both outdoor and indoor. Install batteries in outdoor unit and wait for it to begin sending a temperature signal. Install batteries in indoor unit. You should see outdoor temperature displayed. If not, batteries, transmitter, or indoor unit may be defective.
Nov 16, 2016 | Measuring Tools & Sensors
Indoor unit and outdoor unit not connecting
If the outdoor transmitter and indoor receiver communicated for a time and now don't, it could be time for a battery change. The usual procedure is to change transmitter batteries first, then the receiver. You have to wait for something like 10 minutes for the units to begin to "talk". All of this should be covered in the instructions you received with your system
Oct 14, 2013 | NG Weather NATIONAL GEOGRAPHIC 265NC
Medion md41199 atomic clock, cannot get the outdoor temp to show, how to fix please
Remove ALL batteries in transmitter AND clock.
Insert new batteries in outdoor transmitter.
Insert new batteries in the (receiver) clock.
Wait until outdoor temperature is received AND displayed on clock BEFORE setting time/date/etc.
Mar 11, 2013 | Audio Players & Recorders
I have a TX6470 and cannot receive the outside temp on the inside unit
Double check the batteries to make sure they are installed correctly. If one of the batteries in the outdoor sending unit is in backwards, it will not send the outdoor data. On the indoor unit, there is typically one battery that is used for receiving the signal from the outdoor unit. If all of the batteries are in correctly but that one, you will see the display and the indoor temperature information, but the outdoor information will not be displayed. If there are reset buttons, also try them.
Oct 16, 2010 | Timex TX6490 Wireless Thermometer with...
I changed batteriers and now I can't get a reading from the remote. I have hit the reset on both units. Maybe not in the righ order.
I believe they ask you to press the reset button on the main unit first, but that may not be your problem. Double check the batteries to make sure they are installed correctly. If one of the batteries in the outdoor sending unit is in backwards, it will not send the outdoor data. On the indoor unit, there is typically one battery that is used for receiving the signal from the outdoor unit. If all of the batteries are in correctly but that one, you will see the display and the indoor temperature information, but the outdoor information will not be displayed. Also, make sure the units are close enough to transmit.
Sep 26, 2010 | Oregon Scientific RMR382ABLACK Wireless...
Want start changed battery
Please give me a little more imformation on your problem,wont turn engine over or turns engine over but wont start ?
May 13, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Trouble sending & receiving comcast email messages Motorola q9m
Irecently had comcast email and changed to att email and would lke all my old email imformation changed over to my new one att, how do I go about doing that? I have important imformation that I need to keep. Freddiemumford
Apr 04, 2009 | Motorola Mobility Q9m Smartphone
3M Precision Digital Atomic Wall / Desk Clock with Indoor & Outdoor Temperature and Alarm will not display outdoor temp, i have replaced batteries, outdoor sensor is transmitting, does not appear to...
After replacing the transmitter batteries several times, I tried replacing the clock batteries. They must have been getting low. Once I put in new batteries in the clock it worked fine. Good Luck.
Aug 30, 2008 | SkyScan 86742 Digital Atomic Wall Clock
La Crosse Technology The Weather Channel WS-9662TWC-IT-TBP Wireless Logo
658 people viewed this question
Top La Crosse Technology Measuring Tools & Sensors Experts
robert
Are you a La Crosse Technology Measuring Tool and Sensor Expert? Answer questions, earn points and help others
