SOURCE: cannon bjc-4100 printer
You can download the Windows XP driver here:
http://www.usa.canon.com/consumer/controller?act=ModelDetailAct&fcategoryid=116&modelid=11995
SOURCE: i cant install my canon
What OS are you trying to install it on, and how are you getting the files? The printer came out when Windows 95 was brand new, so using the original installation discs (floppies?) on any newer OS is not going to work. Canon has drivers available online for Windows NT, 95, 98 and Me here.
If you have a newer Windows 2000 or Windows XP use the drivers that are built in to the OS. From the Add Printer option, select Canon as the manufacturer, then look for Canon Bubble Jet BJC-4100.
If you have Windows Vista, this printer is not supported in that OS. Nor is this printer supported in any Mac OS.
SOURCE: Need driver for windows X.P.[My
This download should do it for you: http://drivers.softpedia.com/progDownload/Canon-BJC2100-Printer-Driver-15-Download-51135.html
SOURCE: vista + cannon BJC 250 = error
Go to
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=329&modelid=6729
and try the XP driver. If this doesn't work, you may not be able to interface this printer to Vista.
Let me know if this works.
SOURCE: MY CANON BJC 4100 ISIT APLUG AND PLAY
If you are using XP here is a walkthrough:
1: Click START, then click on PRINTERS & FAXES
2: Click on ADD A PRINTER
3: At Welcome screen click NEXT
4: Select LOCAL PRINTER (if printer is attached directly to computer) and click NEXT
5: Choose LPT1 (in most situations) or a different port if not LPT1 then click NEXT
6: Select "Canon" in left window
7: Select "Canon Bubblejet 4100" or "Canon Bubblejet 4200" in right window
8: Click NEXT
9: Type name for printer or accept default name
10: Click No to "Do you want to print test page".
11: Click FINISH
