Zakes
Support lexmark com
Online support available for South Africa by clicking on Customer Support in the web page above.
Check out the fuse.and the wiring in the plug
Hi if your not sure just call lexmak and one of their agents will be more than happy to help if for any reason it wont work and you have your receipt within the 1 year period lexmark will replace it free of charge. Do not send the ink or power cord they will make out an rma for you and send it to you by email here is their number. 1844 878 8398. Usa. 1800 539 6275 camada
I hope this will reslove your issue
Larry
If your Lexmark X5630 printer isn't turning on, then you have to ensure a few of things before you start troubleshooting the printer to find out the exact cause of the issues.
•The power or data cord isn't detected or broken.
•You're not using a faulty memory card.
•The power switch is correctly set, and the electrical outlet is working.
•The power cord is correctly connected to the power switch.
•The paper tray is working and correctly placed on your printer.
•There is no malfunctioning component inside your Lexmark printer.
In case the problem continues, and your Lexmark X5630 printer is not turned on, you can call on the Lexmark toll-free phone number listed on the Contactforhelp to consult the technician. You will surely get the immediate help and assured solutions for all issues.
1- Make sure the electrical outlet is working.
2- Try different wall outlet.
3-testing with another device to confirm wall outlet is not the problem.
4- don't plug the printer into a surcharge protector.
5- Try another power cord or cable.
6- Plug an unplug the power cord. Let the printer set with 1 hour then plug the power cord.
7- Try to long press on the power button.
Check that the power supply itself got power and give the correct voltage to the printer.
1 Press to turn the printer off. 2 Disconnect the power cord from the wall outlet. 3 Gently remove the power supply from the printer. 4 Reconnect the power supply to the printer. 5 Plug the power cord into the wall outlet. 6 Press to turn the printer on.
Make sure the cord on the back of the printer is pushed all the way into the socket, it should only fit one way. If that fails, check that there is power at the outlet you are using.
Make sure its plugged into a working outlet.
SOURCE: ho do i install my lexmark x5630 printer ?
Yes it is, i dont know where you looked, but it took me 10 seconds to navigate to the drivers.
http://support.lexmark.com/index?locale=en&segment=DOWNLOAD&startover=y&userlocale=EN_UK&question=x+5630&productCode=LEXMARK_X5630&page=answers&detectedProductFacet=CMS-CATEGORY_REF.LEXMARK.PRODUCTS.ALLINONE.LEXMARK_X5630&searchid=1280157230301#2
Hi Mhla Mali, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
My Lexmark X5630, I also used it. And also I faced this type of problem then I have the solutions for it, if you interested with it then I give a site if you browse it googlesupport.co then know it properly.
Un plug the unit for 24 hrs. Reboot and try again. If this does not work you have cuircuitboard issue!
