Just trying to get power to the dishwasher.
It could be a loose connection in a junction or pull box. Loose connections overheat and loose electrical continuity or contact. All electrical connections must be tight.
So the panel is fine - so what! Did you check the power line that feeds the dishwasher? Is it directly wired and not plugged in? Did you use a volt meter? Did you check the wiring for bad connections/ breaks?
SOURCE: Bosch dishwasher SHE44CO2UC/22 no power or light
Hi sir,
first thing to say is that whether it may be an short circuit between circuits,,or due to an over voltage the fuse may be burnt,,please check the control panel..back of dishwasher,,,
if u checked fuse and circuit,,and think no problem with incoming voltage ,,the control panel's capacitors or resistors may be burnt..
if so please go to a tech,,,,,
thank u,,,for using fixya
