Question about LG Dishwashers
No power lg dishwasher - LG Dishwashers
  • 1,162 Answers
A large dishwasher should have a dedicated circuit breaker in the circuit breaker panel, check to see if the breaker is on, tripped, or off, it should be on. If it is on, remove the panel cover and check for power coming out of the circuit breaker, if there is power coming out of the circuit breaker, check for power at the dish washer. Checking for power at the dishwasher may involve pulling the connector cord if any and check the power outlet for power, if there is no power outlet and the dishwasher is hard wired into an electric box, the electric box needs to be opened and the wires need to be tested for power, involving removing the wire splice nuts or wire nuts. Once the power is verified to the dishwasher and the washer is still with no power, a fuse should be sought inside the dishwasher control panel or that the power feed wires are properly spliced. A voltage testor is needed to test for power. electric shock hazard on live wires, please be carefull or call out a electrician or handyman if power testing skill is questionable.
Posted on Aug 11, 2012
  • RAY ACESE Mar 07, 2014
    I'll follow 120v into control panel, etc.
Anonymous
SOURCE:
Lg dishwasher no power
Request a wiring diagram directly from LG.
Apr 15, 2018 | LG Dishwashers
LG LDF6810ST won't power up there is power going to dishwasher
the main control board is fried from what you've described, you will need to dismantle it and remove the board (there will likely be visible signs of damage if there was a burning smell) relatively easy and cheap to replace
Jan 01, 2017 | LG LDF6810ST Stainless Steel Built-in...
How to fix no power problem on LG Dishwasher LDS4821ST
LG lds4821 overheats filter board and burns it. Probably another part shorts and causes excessive current. Replacing the filter board makes dishwasher run but problem persists
Jan 25, 2012 | LG LDS4821ST Stainless Steel 24 in....
LG LDF6810ST Won't Turn ON
If you are still having the problems you describe and especially is you are getting a leak from the lower left door panel, please provide the model number and the serial number.
There IS help available if you provide the info.
Please report back. Thanks!
Dec 27, 2008 | LG LDF6810ST Stainless Steel Built-in...
LG dishwasher LDS5811ST
The problem with the dishwasher acting haunted is probably the main controller card. If you don;t have an extended waranty, know that LG will cover the parts for free through 24 months but after 12 months, the labor will be charged.
Nov 01, 2008 | LG 24 in. LDS 5811ST Stainless Steel...
Dishwasher
If you have confirmed power to dishwasher, you are pobably looking at a control board. I have only run into this one time on a LDS5811 so far. Parts on LG dishwashers have a two year warranty. You have to dissassemble the door to replace the part.
Aug 09, 2008 | LG 24 in. LDS 5811ST Stainless Steel...
LG LDS5811BB Dishwasher
Some of the LG LDS5811 had problems with the wiring harness in the door panel. This is nothing to mess with unless you have disconnected the DW from power.
You can open the door panel by removing the screws around the inside edge of the DW. Or, better yet, firmly but politely contact LG service and tell them you are aware of LDS5811 dishwashers having these symptoms being caused by _melting_ wires in inside the door panel. This is true and even if the DW is out of warranty, LG should fix this problem at no cost to you.
Good Luck!
LD Dishwasher power problem
On the LDS5811 model, I doubt very much that the door switch would cause a full failure.
If you are confident the power is live into the dishwasher, the most common failure with this symptom is a failed controller card (PCB) and will require a service call to LG.
Aug 09, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
Model# LDF6810ST Dishwasher
Your control board may have been fried by the power outage.  Have a qualified LG technician check the unit.  They may have to order a replacement control board.
Jul 14, 2008 | LG 24 in. LDF 7811 Stainless Steel...
Dishwasher not responding to "power"
Check the door switch. THis will kill all power to machine.
Jul 03, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
Dishwashers Logo
863 people viewed this question
Top LG Dishwashers Experts
Marvin
Marvin
Mike
Lollo Pop
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
