Good Morning friend, thanks for your post!
From my understanding your Electrolux washer is not draining. It could be the drain pump, motor, or control panel causing the problem with your washer not draining properly. I would schedule an appointment with a technician to come out and properly diagnosis your washer to avoid any unnecessary part purchases. -Matt
Hello Gene Skates - Typically error code E11 indications that there is an issue with the drain valve, possibly the main control board is timing out before receiving status of drain valve. This is typically not a DIY job and strongly recommend contacting a professional to check the wiring between the main control board and drain valve since you have already replaced the drain valve.
Hello Jason Johnson - Typically error code E11 indications that there is an issue with the drain valve, possibly the main control board is timing out before receiving status of drain valve. I strongly recommend contacting a professional to check the wiring between the main control board and drain valve.
Hello - Typically error code E11 indications that there is an issue with the drain valve, possibly the main control board is timing out before receiving status of drain valve. I strongly recommend contacting the technician that repaired your unit previously to check the wiring between the main control board and drain valve. Some certified technicians warranty their labor and part for 30 days.
