20 Most Recent Electrolux Frigidaire Professional Series 24 in. Built-In Dishwasher Dishwasher Questions & Answers
Sorry for the delay in replying to you, but there has been a technical fault and we have not been able to answer your question.
The 6105G does not have a numeric display, so all of the LEDs flash when a fault is detected, but this does not indicate which fault has been detected. Resetting the dishwasher should clear the error message, but if there is a fault, the flashing LEDs will return after resetting the washer and further investigation will be needed to determine the cause of the fault.
You should be able to reset the dishwasher by entering the engineering test mode and then cancelling it:
1. Switch off the main power to the dishwasher or reset the breaker.
2. Switch the power on again.
3. Press SANITIZE and DELAY START simultaneously.
4. Press the START/CANCEL button to exit
5. Reset the power again.
Please try the above, then let me know if you the error persists and you need further assistance. You can reply to me by clicking on "Add a Comment" below your question.
Regards,
BElectric
Electrolux... • Answered on Mar 03, 2021
CONTACT ELECTROLUX. YOU EITHER HAVE A FAULTY TOUCH PAD OR A BAD RIBBON CONNECTION.
Electrolux... • Answered on Dec 28, 2018
Most likely a control board problem
Electrolux... • Answered on Nov 16, 2017
sounds like you have a bad water valve,if the ice maker is disconnected and water is still filling the ice maker cup the valve is bad
Electrolux... • Answered on Nov 10, 2017
MY OVEN DOOR WONT UNLOCK ON MY FRIGIDAIRE PROFESSIONAL SERIES STOVE 31606390
Electrolux... • Answered on Jul 09, 2016
My service guy told me this was due to the water coming into the dishwasher not being hot enough. He suggested I run the hot water in my kitchen sink prior to running the dishwasher. That seemed to resolve my issue.
Electrolux... • Answered on Dec 27, 2015
Hi Glenn, thank you for allowing me to assist you! Based on the symptoms you are describing, you may either have a communication error from the EOC (electronic oven control) or faulty door lock assembly. Let's try resetting your range by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait roughly ten minutes and then turn your range on. If resetting the power does not correct the issue, at this point I would highly recommend reaching out to a service technician who would be better able to assist you in the diagnosis and repair of your range. You can often locate an experienced technician in your area by going to the manufacturer website.
Electrolux... • Answered on Jan 12, 2015
From your question it is not clear what is leaking water or gas? Dado
Electrolux... • Answered on Jan 11, 2015
Hello theeggleton6 - Sounds like the mechanical thermostat, oven sensor or EOC needs to be diagnosed for replacement. I would suggest contacting a professional to move forward accurately for proper diagnosing.
Electrolux... • Answered on Dec 07, 2014
Hello Gene Skates - Typically error code E11 indications that there is an issue with the drain valve, possibly the main control board is timing out before receiving status of drain valve. This is typically not a DIY job and strongly recommend contacting a professional to check the wiring between the main control board and drain valve since you have already replaced the drain valve.
Electrolux... • Answered on Aug 08, 2014
Hello Jason Johnson - Typically error code E11 indications that there is an issue with the drain valve, possibly the main control board is timing out before receiving status of drain valve. I strongly recommend contacting a professional to check the wiring between the main control board and drain valve.
Good Afternoon Friend, thank you for your post! If you are receiving an error code E11 on your Electrolux dishwasher (EDW7505HPS0A), it usually means that you are experiencing a problem with the drain valve. If you have already replaced the vale and pump, at this point, I would recommend reaching out to a professional or alternatively, visit the manufacturer website for a comprehensive listing of appliance techs in your area that can ensure the wiring between the main control and the drain valve was correctly installed. Best regards! - Z
Electrolux... • Answered on May 27, 2014
Check and make sure the Air Dry button is not engaged. Check the clean out at the bottom. When you push the top rack in insure it is hitting the opening in the back. Finally purchase some Lemi Shine Machine cleaner for the smell, it's likely you have a some stuff lurking in the screens causing the smell, this made my Icon dishwasher work like new.
Electrolux... • Answered on May 23, 2014
Electrolux Frigidaire Professional Series 24 in. Built-In Dishwasher Dishwasher Logo
185 questions posted
Top Electrolux Dishwashers Experts
Mike
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
  • Electrolux Dishwashers
Most Popular Question
door frigidaire professional series will
  • Dishwashers
