After self cleaning the door won't unlock. Have tried shutting off the power and turning back on (didn't work). Tried the self cleaning cycle again and after about 30 seconds a door message is displayed.
SOURCE: Oven Lock stuck open before start of self-cleaning cycle
push in on the oven light switch and hit clean then cancel you have to hold the oven light switch thats what tells the eoc the door is closed if this dont work reply to me
SOURCE: "door lock" light stays on and oven won't work
Same problems. When I removed the lock operating arm nothing happened. Motor is not operating. I've temporarily kluged it by tying the "unlock" (upper) switch circuit together and disconnecting one side of the power to the "locked" (lower) switch. At least we'll have an oven to use, but I'll have to come back and remove the lock motor assembly to find out what's really wrong.
BTW, if some knows those keyed-in service codes they could be useful.
SOURCE: frigidaire gallery self cleaning convection oven
Press and hold the "clean" button for 5 seconds.
SOURCE: F1 is displayed on Maytag Electric Oven
Hi
F1 error means that you have either a bad ERC (clock) or a bad
touch pad. To check these please follow these simple instructions:
thank u
rate me!!!
SOURCE: oven door won t open after self clean cycle
Hello there and welcome to Fixya
This is a fairly common problem with self cleaning ovens
The
problem normally is that the user has interrupted the clean cycle and
the door is locked by default or the door lock assy has failed all
together .
Now here is the thing these ovens have a built in memory
module that stores a number of commands that the user has input in it
like self clean or broil ect.ect so what you will have to do is to
clear the memory and it is done like this.
First unplug the oven and do not touch it leave it sit for a minimum of 1 hour this will reset the memory module
Now
only after the hour is up plug in the oven and you may hear a beep ora
click if so great wait a few min then you can press the cancel button
then try to open the door again.
Now if this has not worked then you
will have to remove the top part of the oven to get to the latch asy
which means you may have to remove part of the back of the oven or the
entire back piece depending on your model to be able to remove the
screws that hold in the top of the oven on the back then you should be
able to see the latch mechanism
Now remove it and have it tested or simply replace it ok
Hope
this helps please keep me informed on how this is going i can send
you a link to a site that has a video on how this is done if needed ok
to help you repair this
Best regards Mike
I appreciate your post, C Maury!
From my understanding your hit the clean button on your Frigidaire wall oven and now the door will not open. I would hold down the cancel button for at least ten seconds, this should unlock the door. If that does not help I would recommend disconnecting power from your wall oven by flipping the household circuit breaker for ten minutes. I hope this information was helpful to some degree. -Matt
