Question about Frigidaire 30 in. Electric Gallery Series Self-Cleaning Double Wall Oven
Here is a link to a website that says the manual is for a wall oven - http://manuals.frigidaire.com/prodinfo_pdf/Lassomption/318205312en.pdf
Here is the link to Frigidaire manuals as well and maybe you can find the manual there if the first link is incorrect -
http://www.frigidaire.com/Owner-Center/Product-Support-Manuals/
Posted on Mar 06, 2015
SOURCE: lost manual to my electric oven, how do you clean inside of oven?
Make shure every thing is out of the oven, and that the door is well locked, then hit the cleaning button.
the oven will clean itself with high temperatures.
HEre is a manual for a frigider oven, should be not too different from yours.
Posted on Nov 20, 2008
SOURCE: I started my oven on ''clean'' -- how long should this take?
Whithout knowing the model number in general it takes several hours for the cleaning cycle. My oven takes approx. 4 hours to complete a good cleaning. On my own oven, you can set the timer for as long as you want. Do you have an owners manual? If not, you can find one here...........
http://www.frigidaire.com/support/manuals.asp
Posted on Mar 21, 2009
SOURCE: display not working nor oven frigidaire gallery smooth top
Could be a thermal cutout or control board problem. If you can email me the exact model number at [email protected] I may be able to help you troubleshoot the cause.
Regards,
Bruce
www.fixyourboard.com
Posted on Oct 05, 2009
SOURCE: Display not working nor oven frigidaire gallery
needs a new control. Easy to replace.
Posted on Oct 23, 2009
SOURCE: The self cleaning instructions for my Frigidaire
Hello- The function is automatic when clean button is pushed. Oven will lock, and turn on at full power for about 90 mins. This 'feature' can, and usually does eventually burn out circuits in the control board. Techs call this the 'self-destruct' option, cheerfully promoted by the salesman. Avoid using 'self clean'! Scrape and clean with light soap/water. Turn on to 450deg. for about 30 min. This is about half the temp. of a 900deg. 'clean' cycle and a lot less expensive in the long run. Please acknowledge this post if info is helpful- have more if needed.- Thanks- Ed
Posted on Mar 19, 2010
