I currently have a Commercial Multiengine License and an IFR rating along with 1200 hours. I have a Canadian passport, is it possible to get a guaranteed job as a pilot in the Canadian air force?
It is not only ******* for a VFR only pilot to fly in the IFR system, it is also potentially very dangerous. Even many IFR rated pilots are killed each year from spatial disorientation. IF you are on a straight in approach to a runway with a localizer or ILS and just tune it in and fly the ILS I don't think that's an issue.
If you're going for a Private Pilot Single Engine Land (PPSEL) certificate you don't need to know anything about IFR approaches. You will learn to fly traffic patterns and all the maneuvers and procedures required for that and for safe flight, learn how to navigate, and learn about airplane systems. You can get a huge head start by looking at websites and you tube links from places like Boldmethod.com, MzeroA.com, and UND aviation.
Older planes are usually very good purchases, IF they have been well maintained over the years. Airplanes have to be inspected annually by an A&P mechanic with an Inspection Authorization so they are usually very well maintained. Any purchase should include having an A&P mechanic review the airframe and engine logs and evaluation of the plane, including looking at how many hours the engine has since overhaul and checking compression. I had a 1966 Cherokee 140 for several years and finally sold it when I bought my current Experimental aircraft (a BD-4). It helps a LOT if you can get an A&P license and maintain you own plane though.
160 is the final approach heading to runway 18. You notice that this approach does not align exactly with the runway, you make a slight right turn to land. 115deg is the outbound leg heading for a procedure turn and 295 is the return heading from the procedure turn, from which you would turn 160 on final and fly the 160 line to the missed approach point. DME is required for this approach so you would either need DME or a GPS that can supply distance information. To fly this full approach (from southerly directions) you would fly to the VOR, fly outbound at 3000' MSL on a 340 heading for about 7 miles then turn left to heading 115 for 1 minute then right turn to 295 and intercept the 340 radial, turn right to 160 and descend to 2300' by GRAMA and continue descending to 1220" at 1.6 DME from the VOR. From that point, if you have the proper visual cues you may descend below 1220' to land, if you can't see the runway environment from 1220 feet at 1.6 DME then you must stay at that altitude until you do see it or you reach the missed approach point at .3DME. There's a very real reason that an instrument rating is required for IFR flight. It takes a lot of training and practice to learn to do it right - and even then you may not have it all correct. (I may well have missed something on this approach but I haven't been IFR current in several years)
Usually, once you have a private pilot certificate you would go for an instructor rating and work as a flight instructor to build flight time (while making money). Along the way you could also be working on your commercial, multi engine, and air transport pilot ratings and certificates. It takes time to get into the airlines, mostly because you need to build flight time and experience. Even when you first break into the airlines the pay is kind of pathetic, but it builds quickly over time.
Technically is you are flying domestic you are not flying over foreign airspace. If flying IFR you must file one. Needless to say when filing a flight plan you must decalre if you are domestic of international flight.
FAA Multi-Engine Airline Transport Certificate or Restricted Multi-Engine Airline Pilot Certificate
2500+ hours of total time minimum.
If Military: >1000 hrs. Total Time. Turbine and PIC are flexible.
1500 turbine (jet) flight time min.
500 PIC turbine (jet) flight time min.
Current FAA Class 1 Medical Certificate
FCC Radio License
No restrictions on International Travel
Current US Passport
Ability to pass a 10-year security background check and pre-employment **** and Alcohol test
Those are the minimum requirements for kalitta. As you can see with 6500TT & 4000+ CRJ time you meet the requirements. It all really comes down to the interview and the impression you leave with the interviewer. I'm with United and it was not so easy to get with them. But once you're in its good.
Becoming a commercial pilot does not *require* a college degree. And many folks are out there crop dusting, performing aerial photography, even teaching flying - all without a higher degree (and some probably without a high school diploma). However, it is NOT the path I would recommend. The higher up the ranks you climb, the more likely any particular institution (whether airline or other) is to want one - even if it really is not directly related to your flying work. With lots of entry level applications, it is just an easy way to weed out the bottom tiers. This is especially true of the airlines.
Also, do not forget that every commercial pilot flies at the risk of their Class II or Class I (the latter required for ATP "airline" flying) medical. I highly recommend that all pilots have a "backup" life plan for the day when they are no longer able to fly commercially.
There are two traditional routes to flying - military and civilian. The military will pay for you to learn to fly, and it is an excellent opportunity and career. But, you have to be accepted by them - and that means good physical and mental condition. And they are most likely going to want to see that you are on at least a path towards a college degree (ROTC, for example). Of course, they are also going to want a long-term commitment from you as well.
Civilian is usually "pay your own way" - at least for the beginning. You can get a pilot's license by working the drive-thru window at McDonalds (to pay for flight school), but it's a tough way to do it. And merely having a license is not enough - you need lots of hours (preferably in jets) to get hired by the major airlines. So that's a lot of time at low wages and strange times - or pay for more of your own training.
Lastly, some airlines do offer ab initio training (training from the beginning), but that is usually foreign (non-US) airlines offering jobs for their own countrymen. Lots of applicants, for a relatively few slots.
Bottom line: Flying is a wonderful career, but like anything else worthwhile - it takes lots of time and effort. If it is something you want to pursue, then don't be afraid of working long hours at perhaps multiple jobs to earn enough money to start getting your license. And then more hours and strange times at relatively low wages to make it into the airlines.
