Would like to change defrost via AC cold air to defrost via hot air.
There is a 98% chance it is your electric heat pump. Because Jaguar uses the closed water circulation method. Now the heat pump primary function is to supply or pump coolant to the heater core at low rpms or at idle. Once the heat pump fails it can actually block or significantly slow the flow of your coolant. I have fixed around 20 Jaguars with heat related problems ( xjr,xj8,x-types,s-type) all had a bad or very dirty heat pump. 5 of them i was able to clean the rest had to be replaced. Note... a bad heat pump can create a back pressure which in turn force or push coolant out at the connection (a small 3 way coupler) located at the bottom of the coolant reservoir tank given you the appearance of coolant leak. I mean you will have a coolant leak but once you replace the heat pump the coolant leak at that coupler will stop. Also back pressure can stop the coolant flow blowing your intake manifold or head gaskets. The heater control is located on the radiator under the coolant reservoir tank it has only one bolt 10mm. You well have to remove the top post radiator hose and the coolant reservoir tank. there's 1 bolt holding the coolant reservoir bolt on it's a 8mm
Turn the temperature up to the hot to blend the hotter temperature
NO HEAT ON FLOOR VENTS
As
per your problem mentioned. There are few solved help links to
troubleshoot these problems. Go through the list and Click the link below:----
http://whatisbyme.blogspot.in/2012/05/2000-toyota-avalon-no-heat-on-passenger.html
http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
http://repairhelpcenter.blogspot.com/2012/01/hot-air-on-drivers-side-vents-only.html
http://technoanswers.blogspot.in/2012/04/1992-toyota-camry-ac-control-light.html
http://technoanswers.blogspot.in/2012/02/no-heatblower-blows-only-cold.html
http://whoisbyme.blogspot.in/2012/06/2009-mercury-grand-marquis-ac-blows.html
http://schematicsdiagram.blogspot.in/2012/04/ac-not-blowing-through-vents-on-2007.html
http://schematicsdiagram.blogspot.in/2012/04/passenger-side-temperature-is-warm-air.html
These
will help.
Thanks.
As
These will help.
Thanks.
To troubleshoot this types of problem,click the link below
:----http://howtobyme.blogspot.in/2012/02/heater-blows-only-from-defrost.html
--------Go through the procedure to confirm the
issue.
Engine Overheats and heater
blowing cold?
http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
Heat blows cold on drivers
side and hot on passenger side?
http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html
No heat on car?
http://technoanswers.blogspot.in/2012/02/no-heat-on-oldsmobile-silhouette.html
Heater blows intermittently and temp
gauge goes erratic?
http://technoanswers.blogspot.com/2012/01/heater-blows-intermittently-and-temp.html------------Heater blows cold?
---------Car heater blowing warm, but not
hot air?
http://schematicsdiagram.blogspot.com/2011/12/car-heater-blowing-warm-but-not-hot-air.html--------
Heater/AC blower motor not working?
http://technoanswers.blogspot.in/2012/02/heaterac-blower-motor-not-working-on.html
A/C, heater, defroster fan, not
working?
http://technoanswers.blogspot.in/2012/02/ac-heater-defroster-fan-not-working.html
Heater problem?
http://technoanswers.blogspot.in/2012/02/heater-problem-on-isuzu-trooper.html---------
This will help.Thanks.
Thank you John. Would you happen to know the defrost can be changed from ac to hot temp? The blending of air proves unsuccessful. I really appreciate you!
