Exactly after 6 secounds the Lamp Power switch off, then after 10 Secounds the Lamp switch on for 6 secounds. This cycle repeats three times, then after 30 secounds (cooling process) Projector goes in standbye. There are no Error Signals from LED's.
The lamp ballast board controls the lamp. It most likely is the cause of the problem. Go here to see if they have the part you need. TV Parts Universal TV Stands DLP Chips ShopJimmy
SOURCE: Sanyo PLC-XU47 seems to power cycle
Welcome to resolve the problem if you please say what are the solution to me the same problem
SOURCE: Projector overheats after 30 minutes and shuts down
Is the fan in your projector still working in high speed or not spining?
SOURCE: lamp goes out after 10-15 seconds
Recently had a similar issue.
When I took the lamp out (Let it cool for awhile first), there was dust all over one side preventing air from the fans from cooling the lamp, so it shut itself off after getting too hot.
SOURCE: SANYO PLV-70 - powers up for approx 5 secounds and then turns of
we had this problem and it ended up being that one of the fans under the lens assembly was not working, causing the system to shut down when it tested it at startup
