20 Most Recent
Mitsubishi WS-55813 55" Rear Projection HDTV Questions & Answers
Mitsubishi WS-55813 screen goes blue then power goes off
It appears to be a common problem with these units. Looking at the chats in different forum on the internet including fixya.com, this problem is reported as early as 2 years ago by some users.
The solution might involve going to a technician to fix it. But if you have the original remote unit and the manuals then first try to do a hard reset of the TV to the default factory settings. You will loose all the programmed channel selections etc.
Good Luck.
Green blinking light on Mitsubishi WS-55813 HDTV
generally this means a bad digital module.. as a techinican the first thing that we would check are what is know as standby voltages. if they were there we would replace digital module.! question. Does it blink for more than 70 seconds. This unit comes with a lockout feature. to unlock press and hold menu down for 10 seconds on front panel.
My mitsubishi projection tv, ws55813, was losing
There is a hard reset you can try on this set--it is done with the Mitsubishi remote that came with the set.
Confirm actual model number and I will tell you how to try it. The set will shut off after the reset(not the reset button some of these sets have on the front) and come back on channel 3 in the air band--any labels for inputs will be replaced by original input numbers etc.
No guarantee this will fix your problem but it will return the set to the condition it was when new in the box.
Let me know if you want to try this.
SD TECH
Mits. 55" Model 55511
Get you a little solder and a cheap soldering iron and try soldering the vertical output ic which is mounted on a heatsink on the circuit board. Be careful when disconnecting plug connectors and I suggest marking them as you disconnect them. Also resolder the convergence i.c.s which are mounted on the largest heatsink on the board. Vert. i.c. has about 9 - 11 pins and convergence have about 25 ea. Start by carefully undoing all wire ties, remove the few screws that hold in the board then slide it back towards you to access bottom(solder side). For the most part, any component that is mounted to a heatsink gets hot and cools down when set is off causing cold solder joints. So any part mounted to a heatsink is suspect. This repairs a high percentage of sets like yours. Good luck, Russmann.
Green LIght Blinking
replace the DM or have someone repair the DM. The capacitors are bad and someone who knows how to repair circuit boards can replace them
Screen blacks out
Check your set for coolant leakage. It is very prevalent on Mits HDreadys.
If your 4 layer Signal board - beneath the blue gun - has coolant on it, you'll have problems finding a replacement. If it's the boards under the other 2 guns, they can always be repaired as they are single layer.
A drip shed should be installed to keep the coolant off your boards.
Mr Bob
