20 Most Recent Sanyo PLC XU33 Multimedia Projector Questions & Answers
Switching of Projector within few seconds ??!! This problem is common when Projector lamp is not replaced with that of the same band & model but one can fool the projector lamp as it powered with logic switching ...0 V or 5 V set by its company ... Go through following Web : http://www.diy-community.de/forumdisplay.php?f=60 http://www.allinbox.com/modding.htm http://www.dity.nl/forum/lampen/442-...qi-lampen.html http://recklessphilosophers.com/2008...ad-of-300.aspx
Sanyo PLC XU33... • Answered on Jan 13, 2021
We have a similar situation with our Sanyo Pro Xtrax. It will be on for about a hour and then the "warning temp" light would come flashing red, and the project would turn off on its own.
Sanyo PLC XU33... • Answered on Dec 10, 2017
Owner decided to upgrade to a newer projector. Lamp was too expensive.
Sanyo PLC XU33... • Answered on Nov 09, 2015
hi,
check the video inputs. if there is no video input then the projector will goes off after count down.
also check that is the lamp replace light lights up or not. if its lights then you have to change the lamp and then reset the lamp hour.
ok
Sanyo PLC XU33... • Answered on Jan 19, 2011
Sounds like your input is set for componebt video instead of VGA
Sanyo PLC XU33... • Answered on Aug 15, 2010
Most of the Apple iBook G4 series have a video out port on the left side. This is a non-standard port and would require the use of an adapter (Apple VGA Display Adapter) that is normally included with the laptop package when first bought. The VGA's output connector is the standard 15 pin HD D-Sub (HD-15).
On the other hand, the Sanyo PRO XTRAX projector is capable of multiple input type of connectors. They are: a) RCA type composite video in, b) DVI, c) RGB, c) RS232, d) S-Video, e) USb and f) VGA. You would then be using the latter, VGA since it matches the Apple VGA Display Adapter.
To connect the iBook to the projector, you would need a length of VGA cable that are available in most projector/computer stores. Here, here and here are examples of commercially available.
Hope this be of some help/idea. Pls post back how things turned up or should you be in need of additional information.
Good luck and kind regards.
Sanyo PLC XU33... • Answered on Nov 07, 2008
theres prob something wrong wif the bulb
Sanyo PLC XU33... • Answered on Dec 20, 2007
Sanyo PLC XU33 Multimedia Projector Logo
Popular Tags
18 questions posted
Top Sanyo Office Equipment & Supplies Experts
k24674
Rob Hill
Rob Hill
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Sanyo Office Equipment & Supplies
Most Popular Question
sanyo pro xtra projector warning light
  • Office Equipment & Supplies
