I found a wiring diagram. Pic would be easier than trying to explain...but it won't let me put pic on here. Just take positive from one voice coil and negative from the other and hook up to channel of the amp. Daisy chain to the other sub. The other positive and negative left needs to have a jumper wire...(ea sub). That wires a pair. Just do the same to the other 2 subs for the other amp channel.I found a wiring diagram. Pic would be easier than trying to explain...but it won't let me put pic on here. Just take positive from one voice coil and negative from the other and hook up to channel of the amp. Daisy chain to the other sub. The other positive and negative left needs to have a jumper wire...(ea sub). That wires a pair. Just do the same to the other 2 subs for the other amp channel.
You can't post conmments that contain an email address.
Is the amp a single channel? If so, the only way to connect the subs (without overloading the 2 ohm stable amp) is to wire each sub's voice coils in parallel (2 ohm) and then connecting the subs in series (4 ohms). If the amp is two channel, the subs can have their voice coils connected in parallel (as before) and then each sub connected to its own channel.
Things to check: Is the wire between the amp and the subs heavy enough to pass 167 amps? 2000 * 12 = 166.66666 amps. Max volts on the subs are 10 volts....close enough. Are you sure you're using the line out on the head unit? You may be over driving the amp if it's anything else.If the head unit doesn't have line out connectors then you'll need to get an attenuator for each channel. Do you have caps on the 12 v power in wires? They'll keep the headlights from dimming and the alternator will last longer if you do.
Based solely on spec sheet information the Lanzars can handle 1300 watts RMS and the KX1200 is rated at 300x1 @ 4 ohms, 600x1 @ 2 ohms, & 1200x1 @ 1 ohm. Even with a 1 ohm load you will still only be providing 600 watts to each sub. While the kicker will provide more power at 14+ volts, no car creates more than 12-13 volts via its alternator. A car battery only provides 12.6 volts. So you will be loking at 1200 watts from 1 channel as a best case scenario.
Additionally, with your 2 subs, they will need to both be Dual 4 ohm voice coils in order to net a 1 ohm final load. Each voice coil will need to be wired in parallel and then each speaker needs to be wired in parallel.
run them straight and dont use the cross over. One speak on right channel and the other on other channel. Then turn up amp settings 7/8 the way up and control the rest from your dvd/cd player. I recommend some monster cable which is very thick. Ground the amp directly to trunk bolts but make sure to scrape the paint off or the connection will be bad. You can also use a cap which will send battery pulses to amp much quicker.
Your PSW815 has 2 ohm dual voice coils allowing you to better match the impedance to your amp. Each voice coil is 2 ohms. If you wire them in parallel (both +'s together and both -'s together and then to the amp terminals), the sub presents a 1 ohm load which is too low for most amps. Wiring the voice coils in series (one + to the other - and the remaining + and - to the amp terminals) results in a 4 ohm load.
This link shows the wiring diagram for both options. If you know for sure that your amp is 1 ohm stable, use Wiring Option #1. If the amp is not 1 ohm stable, use Wiring Option #2.
The only way to wire a single 4ohm DVC sub to present a 4ohm load is to just connect one voice coil. If you wire the coils in parallel, you get a 2ohm load. If you wire them in series, you get an 8ohm load. But it will work great with just one voice coil. Or if you really want to use both voice coils, and your amp isn't stable at 2ohms, wire the voice coils in series and present an 8ohm load to the amp. It'll work fine, it just won't deliver quite as much power.
In short yes. And is very common even has its own term called bridged. Taking two channels and making them one. I would hope that you are running a cap. that's going to put out a lot of power and stress on your battery
Need to know how's may channels and I can help you
2 channel 2ohm stable
