Question about Alphasonik PSW815 Car Subwoofer
I have 2 positives and 2 negatives on back of my alphasonik sub, do i connect amp to one side or both sides?
Posted by gaz69 on
Ronny Brite
  • 655 Answers
Hello gaz69,
Your PSW815 has 2 ohm dual voice coils allowing you to better match the impedance to your amp. Each voice coil is 2 ohms. If you wire them in parallel (both +'s together and both -'s together and then to the amp terminals), the sub presents a 1 ohm load which is too low for most amps. Wiring the voice coils in series (one + to the other - and the remaining + and - to the amp terminals) results in a 4 ohm load.
This link shows the wiring diagram for both options. If you know for sure that your amp is 1 ohm stable, use Wiring Option #1. If the amp is not 1 ohm stable, use Wiring Option #2.
Hope this helps.
Posted on Aug 09, 2009
Anonymous
    Scholar:
  • 129 Answers
Hey gaz, you have purchased dual voice coil sub woofers. Each coil has it's own impedance, Usually 4 ohm, or 2 ohm (1 ohm in the case of some high end woofers, and 3, or 6 ohm in the case of some JL, and JBL woofers). How you wire up your coils depends on the amplifier you are using.
THe Alphasonik 800 series sub's are Dual 2 ohm woofers. so you can run one singe sub @ 4 ohm's or 1 ohm. If you have a pair you will be running @ 2 ohm's or 1/2 ohm. (not many amplifiers can handle 1/2 ohm)
Here is an in depth guide that will help you with the wiring configuration.
http://pinq.wordpress.com/2007/05/11/wiring-your-subs-dual-voice-coils/
2 things you MUST know before wiring.
The impedance of each coil.
The lowest stable impedance of the amplifier.
DO NOT WIRE YOUR SUBS LOWER THAN THE STABLE IMPEDANCE OF THE AMPLIFIER. GOING HIGHER IS OK, BUT NEVER LOWER.
  • Anonymous Aug 09, 2009
    NEVER just use one coil of a dual voice coil sub woofer! This WILL damage the driver!
Does anybody know what watt this is. it's sosed to be a 2400 watt and why does it have 2 ports on each side to hook up speaker wire And what's the best way to run it with a 800 watt Rockford fosgate
dual voice coil subs hook up mono on amp, from amp - from right side + from left side of amp run to sub n then jumper wires from one side of sub to the other side goes negative jumps on positive and positive jumps on negative
Apr 03, 2015 | Rockford Fosgate Car Audio & Video
There are 2 input ports on the sub woofer. How can i connect them to mono amp
subs usually allow a bridge where you connect the mono positive to one side positive and the mono negative to the other side negative. Does it not mention this in the instructions? If you don't have the instructions, try it. It can't hurt anything, but use low volume when checking. If you want to verify the bridge before hooking up, use an ohmmeter to look across the positive on one side to the negative on the other. If one combination is open or more than 8 ohms, try the other set of positive and cross-negative. OK?
Dec 01, 2010 | Pioneer C-Type TS-W306DVC Car Subwoofer
Wen radio is turned up ampp goes into protection
No diagram but you can printthis out. Choose 1 set of inputs for the subs on the amp (I usually use the low or rear which ever has more settings) You need to put the settings to low hertz and no high settings. Now in the output side you're going to use the positive side of the right side speaker and the negative side of the left side speaker (you can switch left or right as long as they are opposite sides!). Lets start with the negative wire connect it to the negative input on one of the subs, connect the positive wire to the positive input on the OTHER sub, then get an extra wire to connect the inputs not used on both subs. Adjust settings in amp and radio and if it doesn't sound good use negative and positive outputs from one single output (only left or only right) Hope this helps
Oct 08, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
Need a diagram of hw to hook 2 subs to 4 channel amp
Oct 08, 2009 | Kenwood Car Audio & Video
I have a jesen ka5 5channel amp plus mono and i dont know how to hook up the subs to the mono
Ok, you're going to choose 1 set of inputs for the subs on the amp (I usually use the low or rear which ever has more settings) Now in the output side you're going to use the positive side of the right side speaker and the negative side of the left side speaker (you can switch left or right as long as they are opposite sides). Lets start with the negative wire connect it to the negative input on one of the subs, connect the positive wire to the positive input on the OTHER sub, then get an extra wire to connect the inputs not used on both subs. Adjust settings in amp and radio and if it doesn't sound good use negative and positive outputs from one single output (only left or only right) Hope this helps.
Oct 01, 2009 | Jensen Car Audio & Video
Alphasonik amp is getting power but no power to subs
either your rca inputs are bad or your mosfets are bad
Jul 05, 2009 | Alphasonik PMA1000D Car Audio Amplifier
SUB WOLFER WIRING
im assuming you have 2 subs that are DVC? if thats the case, wire from the positive on the amp to the positive voice coil 1 on sub 1 to the positive on voice coil 1 on sub 2. then do the same with the negative sides. then on the second voice coil of sub 1, connect a wire from positive to negative. do the same for sub 2.
Nov 27, 2007 | Car Audio & Video
Sub hook up to PPI D3000 amp
I'm not familiar with this amplifier but in most cases, if a mono amp has more than one positive speaker terminal and more than one negative speaker terminal, the positives are directly connected and the negatives are directly connected. So  as long as you connect the speaker positive to a positive speaker terminal of the amp and the speaker negative to a negative speaker terminal of the amp, it will work properly.
Oct 12, 2007 | PPI D3000/1 Car Audio Amplifier
Sony amp bridging
Your amp, being a 2-channel amp, should have 2 speaker connections with a negative sign(-) and 2 with positive signs(+)...Take your speaker wires (You will need 4 of them) and twist the ends of 2 of the together and put them into the negative spot on 1 side of your amp. Assuming you have 2 subs, connect them 1 to each sub and be sure they are on the negative sides of the subs or both are on the same side of the subs. Then do the same with the positive leads except to put them in the positive spot on the opposite side of the amp. So you will have the negatives from one side's outputs (or channel 1) and the positives from the other side's outputs (channel 2). Thus, your amp will be "bridged" across both channels. Hope this helps...just comment back if you need a diagram or something. And be sure to leave feedback please.
Oct 05, 2007 | Sony Xplod XM-1652Z Car Audio Amplifier
Verge VGA300M Speaker terminals
Mono amps often have two sets of speaker outputs; this is just to simplify multi-speaker connections. The two positive and negative terminals are connected together internally, so they're effectively the same as one terminal. There's no difference between connecting both subs to the same positive and negative terminals, or using different terminals for each sub; electrically they'll all be connected together either way.
Jun 06, 2007 | Verge VGA300M Car Audio Amplifier
Alphasonik PSW815 Car Subwoofer Logo
921 people viewed this question
Top Alphasonik Car Audio & Video Experts
Marvin
Marvin
Are you an Alphasonik Car Audio and Video Expert? Answer questions, earn points and help others
