20 Most Recent
Lanzar SDN7UD Car Video Player Questions & Answers
We're does the rear view
if i remember correctly, on your back up camera there are 2 wires a red one (power) and a black (ground). you will need to pull off one of the tail lights and find the reverse bulb/ wire. u will take the ground wire and mount it to the frame of your vehicle. then u will need to find the power of the reverse light. take the red wire and splice into the power of the reverse. u will then need a separate wire and run it from the spliced wires to your lanzar player. doing it this way will make the camera come on and the lanzar to switch to view when u have your vehicle in reverse
Pleace help ! with bypassing
Unfortunately, I cannot find a good manual on this unit so I am having trouble determining what the wire color is for the brake wire. Usually these units need to see a constant ground in order to work. You can try hooking that wire up to your ground wire, not advisable though. You could try hooking it up to a switch. You more than likely would have to us a certain combination in order to get it to work like flipping it on and off a couple of times, but still is effective. You would have to consult the manuals to find out if there is a combination or not. The other, and most effective, way to make it work is by using a relay. You would just wire up power, ground, and the brake wire to the relay.
