20 Most Recent Lanzar (MAXP154D) 15'' 2000 Watt Dual Voice Coil Subwoofer Driver for Small Enclosures Car Speaker Questions & Answers
1000watts RMS and 2000 peak
Lanzar... • Answered on Jan 06, 2015
There are 4 connectors on each side of the Problem with the Lanzar 15'' 2000 Watt Dual Voice Coil Subwoofer Driver for Small Enclosures Car Speaker. how do i wire it so i can put the sub in the box so i can connect it to my amp?
Lanzar... • Answered on Jul 28, 2014
If each voice coil is rated at 2-ohm, then wire it in "parallel". This will make a 1-ohm total load.
amp pos. out to coil 1 pos. to coil 2 pos.
amp neg. out to coil 1 neg. to coil 2 neg.
If the they are dual 4-ohm, the rating would be 2-ohm in parallel.
Tell me how many subs and what are the types as well as ohms for each.
Lanzar... • Answered on Jun 18, 2014
Send me the type and model of vehicle it is going into. From there we can determine what type of sub box to build.
The car falling apart is a NO. But if you want a lot of Boomy Bass, then make sure to make a ported box for your sub woofer and give it the power it needs. If i knew the exact model i would tell you the size of box and amount of power you would need to amplify it. dreamsystems
Lanzar... • Answered on Feb 10, 2011
use a decent wire (same gauge as you would use to connect it to your amp) and connect it between the "+" pole of one coil and the "-" pole of the other coil. use the 2 other poles to connect the speaker to the amp. Have a nice day!
Lanzar... • Answered on Dec 14, 2010
Hello dexterchapma,
The only way to wire a single 4ohm DVC sub to present a 4ohm load is to just connect one voice coil. If you wire the coils in parallel, you get a 2ohm load. If you wire them in series, you get an 8ohm load. But it will work great with just one voice coil. Or if you really want to use both voice coils, and your amp isn't stable at 2ohms, wire the voice coils in series and present an 8ohm load to the amp. It'll work fine, it just won't deliver quite as much power.
Hope this helps.
Lanzar... • Answered on Jun 28, 2009
In short yes. And is very common even has its own term called bridged. Taking two channels and making them one. I would hope that you are running a cap. that's going to put out a lot of power and stress on your battery
Lanzar... • Answered on Feb 10, 2009
When an amplifier causes trouble or otherwise stops working, it is necessary to eliminate external possibilities such as a short circuited output. If nothing external is causing the problem, unless you have a good friend who is an electronics engineer, it will be a repair shop task...
Lanzar Car Audio... • Answered on Apr 27, 2020
Check your fuses. Check to see if any of the wires are loose. Could be a blown fuse or loose wire. Possibly the following link might be of interest: https://www.youtube.com/watch?v=xMbsieEj0UM
Lanzar Car Audio... • Answered on Mar 15, 2019
Lanzar (MAXP154D) 15'' 2000 Watt Dual Voice Coil Subwoofer Driver for Small Enclosures Car Speaker Logo
19 questions posted
Top Lanzar Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Marvin
Marvin
Muntejaya Ginting
Muntejaya Ginting
Are you a Lanzar Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Lanzar Car Audio & Video
Most Popular Question
rms wattage lanzar max pro 15
  • Car Audio & Video
