Peter
you are too short on details like make model , 2 stroke or 4 stroke
read your user manual or look on the petrol cap as most have the ratio on the bowser emblem
so for an answer, it is most likely a 2 stroke and so-- yes-- it will require a oil/fuel mix in the tank
if you do not know it , start with a ratio of 40:1 ( 40 fuel -1 oil) and only use 2 stroke oil not normal engine oil
run at rpms and there should be a trace of blue smoke
too much smoke cut the oil back to 50:1 and no smoke increase the oil to 30:1
go google and type in user manual for ( make and model ) --and the ratio will be in that print put
