20 Most Recent Briggs & Stratton Briggs Stratton Lawnmower Lawn Mower Short Block Questions & Answers
Briggs & Stratton 19.5 HP engine. How to tune the carburetor please?
Question edited for clarity, Australian to American English Question moved to Briggs & Stratton. Check out the link and video https://www.google.com/search?q=Briggs+%26+Stratton+19.5+HP+tune+carburetor and also https://www.google.com/search?q=briggs+and+stratton+19.5+hp+carburetor+adjustment ....
11/16/2023 6:08:29 AM • Briggs &... • Answered on Nov 16, 2023
I have a twin cylinder Briggs & Stratton engine that I cannot get to stop. I ran the wire from the coil to a switch then to earth but it will not stop?
Question edited for clarity. Question moved from MISC. Put the switch on the positive supply to the coil. Or find out what was faulty in the original set up?
9/7/2022 2:16:42 AM • Briggs &... • Answered on Sep 07, 2022
Mcculloch m3540p
https://www.manualslib.com/ Try this site for your manual.
4/3/2019 6:29:11 PM • Briggs &... • Answered on Apr 03, 2019
Lawnmower manual rover qstart i4500
This site has a lot of manuals Try it https://www.manualslib.com/
4/3/2019 6:28:43 PM • Briggs &... • Answered on Apr 03, 2019
Help finding Makita lawnmower PLM4623NP Manual
Try this site for the manual you need. https://www.manualslib.com/
4/3/2019 6:27:04 PM • Briggs &... • Answered on Apr 03, 2019
500 E Briggs &stratton runs for a second then cuts off
Sounds like a fuel problem. Check the lines and filter.
4/3/2019 6:14:51 PM • Briggs &... • Answered on Apr 03, 2019
3answers
Fuel problem with John Deere 23hp engine
time to pull the hose off the fuel pump coming from the tank and drain the tank and check flow of gas coming from tank hose, and possibly inline fuel filter is plugged or there is junk in your tank/line from tank not letting enough fuel to run to pump so pump can pump it to carb !
8/11/2018 10:03:14 PM • Briggs &... • Answered on Aug 11, 2018
Power more 173 cc will not start unless I poor a little gas in carb, runs for a few seconds. cleaned carb full of fuel, bowl fills up. manuel choke works, no gas shut off valve, two butterfly valves.
My first thought would be the screw that holds the carb bowl. It has a little orifice and 4 holes evenly spaced around the base of the screw and it is vital that all holes and orifices are completely free of gunk and trash or varnished gummed up stuff. That must be cleaned. I use B-12 Chemtool carb jet spray. I suggest using compressed air as well. An old guitar string (G,B,or E strings) works well but do not make sharp bends with the wire! It will snap off at the right time and poke your finger. This case calls for a little common knowledge Lol. And supposing the main jet has been sprayed and blown out. Main jet is the tube with many evenly spaced holes around it. Some are removable. I clean my carbs using a welders torch tip cleaner files. Never ever ever force a wire too large in these orifices and holes. Always use the nxt smaller size wire.
6/26/2018 6:03:38 AM • Briggs &... • Answered on Jun 26, 2018
How do I find a user/operators manual for a
Parts Tree.com
6/10/2018 12:25:17 AM • Briggs &... • Answered on Jun 10, 2018
Lawnmower manualsHRX 426
try PartsTree.com
4/11/2018 12:08:13 AM • Briggs &... • Answered on Apr 11, 2018
What kind of oil should i use on my briggs & stratton mower, 158cc?
HD 30 WT.
3/28/2018 1:09:38 PM • Briggs &... • Answered on Mar 28, 2018
What kind of oil should i use on my weedeater mower, 158cc
2 cycle engine oil
2/27/2018 2:09:33 PM • Briggs &... • Answered on Feb 27, 2018
Craftsman owners manual model 944.362400
SearsPartsDirect they may have one you can download if not try PartsTree.com
2/8/2018 12:10:24 AM • Briggs &... • Answered on Feb 08, 2018
Masport 430 mower engine pulsing
Check the spark plug is clean
10/15/2017 9:00:39 PM • Briggs &... • Answered on Oct 15, 2017
Motor will not Idle up to Medium or High
Does the engine want to bog down when you move the throttle? Or does it do absolutely nothing? If it bogs down when you try the throttle, It could be: water in the gas bad or distorted diaphragm (if no float) stuck needle valve stuck float I’m happy to help further over the phone at https://www.6ya.com/expert/karl_14766549451f8563
7/19/2017 6:46:46 PM • Briggs &... • Answered on Jul 19, 2017
2answers
Need repair manual for briggs
After a very extensive cross reference session your engine is model number
10H902-0285-E1 (not provided by you so it took a while)
Your engine is covered in this repair manual:
http://www.mymowerparts.com/pdf/Briggs_&_Stratton_Service_and_Repair_Manuals_Spec_Charts/270962%20Single%20Cylinder%20L-Head%20BRIGGS%20&%20STRATTON.pdf
If there is a problem that your having I can help you if you would just elaborate. I could save you lots of time. The 2 most common failures of this engine is on the carburetor. The parts that fail are the diaphragm (Item 394) and the primer bulb (Item 976) of this link:
http://www.partstree.com/parts/?lc=briggs_and_stratton&mn=10H902-0285-E1&dn=57160004
Carb data is in section 3 of the first link.
Thanks for choosing FixYa,
Kelly.
4/2/2017 12:59:35 AM • Briggs &... • Answered on Apr 02, 2017
HOW DO I REFIT THE CAM TIMING PINION?
you don't. if it spun on the shaft then you have to replace the cam.
1/3/2017 8:40:57 PM • Briggs &... • Answered on Jan 03, 2017
What Gap for spark plug on 3.5 hp engine?
.030 or 76 MM
6/26/2016 1:14:09 AM • Briggs &... • Answered on Jun 26, 2016
Fuel leaks out of the primer bulb has a nipple with small hole. fuel coming out of the nipple hole. No breaks or tears in the bulb.
ethanol additive in gasoline causes deterioration of fuel system parts, especially primer bulbs. Needs to be replaced...relatively easy for mechanically minded or bring to dealer. Check Amazon for parts...they are cheaper than most dealerships. Hope this helps....
5/1/2016 10:40:31 PM • Briggs &... • Answered on May 01, 2016
Briggs & Stratton Briggs  Stratton Lawnmower Lawn Mower Short Block Logo
446 questions posted
Top Briggs & Stratton Garden Experts
Jay Finke
Jay Finke
john h
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
View Most Popular
  • Briggs & Stratton Garden
Most Popular Question
fuel leaks out primer bulb nipple small
  • Garden
