Android Huawei Logo
J
Joan Marie Tucker Posted on May 19, 2016
HOW DO I GET THE PHONE TO RING LONER WHEN RECEIVING A CALL
Harry
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jun 01, 2016
Harry
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
65
Points
Most phones have a volume slider for the ring in the setttings.
My phone will not ring when receiving calls.
Press Menu. Select "Answering Setup" and see if you can solve your problem there.
1helpful
Not receiving fax- line is busy to all senders
Go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set. Make sure the phone wire which you insert in fax machine getting proper dial tone and getting out going calling facility.
Have a nice day and do not forget to rate please...!
Stopped receiving faxes ten days ago. Can still send faxes. Senders say it just rings and rings. Calling the fax by phone confirms many rings, then fax belltones. What do you think is the problem?
go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set.
Phone ring is not coming through on my phone for the fax machine
Fax machines are ANALOG devices and will not work reliably on DIGITAL phone lines. you cannot set a fax machine to digital.
Making calls
I turned the phone off and then on. Either that did it or it solved itself.
The phone will not ring when receiving a cal
the ringer speaker is in miscontact so if u are good at opening then just open it and refit it including speakers then check it...
if problem persists then replace the speakers with the new one....
otherwise visit the technician.........
Top Android Cell Phones Experts
ADMIN Eric
ADMIN Eric
NOEL
NOEL
Steve Sweetleaf
Steve Sweetleaf
Are you an Android Cell Phone Expert? Answer questions, earn points and help others
