Question about Android Huawei
What does it mean when t says message pending on a sent text on my android phone
I sent a text message over an hour ago and it says message pending when i view status report
Posted by sheila mccarty on
Diann Blanchard
    New Friend:
I go through Straight Talk, and sometimes it will say this on certain peoples messages and they will respond and it will still say this. it can also mean the person has not read the message yet if they have set their phone set to notify the respondent. if the person has it set NOT to let the person know they have read or received the message it can say this permanently and they will respond whenever they get it, if it has never said that for this person before assume they have changed the setting.
Posted on Jun 01, 2015
Elizabeth Vigna
    New Friend:
    Problem Solver:
  • 19 Answers
Agreed. You can't really do much though in that situation because my phone does the same. It's just a bad effect on the android itself. I would just restart the phone and try again.
Posted on Feb 06, 2015
mordyt
    Problem Solver:
  • 5 Answers
Depending on your coverage, cell provider, and network it is being sent to, it might take a little while for the message to go through.
You can try a reboot.
Posted on Oct 18, 2013
2answers
How can I recover a text message to landline
no root !
Can you retrieve deleted text messages on Android? Yeah, this video will show you the full guide for Android text message recovery. Don't hesitate and recover deleted text messages from Android 4.0, 4.1, 4.2, 4.4, 5.0, 5.1 and more versions right now!
Not only can you recover SMS messages from Android backup but also can recover Android SMS messages without backup. This video is showing you how to recover deleted sms messages on Android without root your phone.
Some common situations that lost text messages you can recover from:
1. accidentally deleted texts on your android phone
2. lost text messages after Android 5.0 updated or other Android upgrade.
3. save text messages from water damaged, crashed, broken or smashed Android phone
4. Android deleted text messages randomly by itself
5. Factory restore Android phone.
And more...
Watch this video and share it with your friends too so that they can also get their precious lost data back.
Mar 16, 2015 • Cell Phones
I have sent a text message I shouldn't have sent and it is still showing as pending, can I remove or delete it???
You can delete it from the message option box, however it cannot be stopped from getting delivered. Its pending because the person's phone either is out of coverage area, switched off, or the message box might be full and it will get delivered once the problem is been resolved
3answers
How to recover deleted sms (phone memory)from sony ericsson aino ?
And more...
How do you text
follow the steps below to send text
  1. login and select 'Send New Text Message' link from the Inbox, Outbox, or Pending views.
  2. Type in your text message and save for sending.
  3. Run the Motorola TEXT application on your phone, and your text message will be sent. Your message record will be moved out of the Pending folder into your Outbox online.
1helpful
The problem I described is on the Nokia n95
Normally, the red spot on an envelope in the sent messages means that your text has not been delivered to the destination phone number the text was sent to.
In some other phones like some nokia phones, there will be an exclamation point "!" on the envelope of the failed delivery sent message.
A message may fail to be delivered due to a number of reasons, like network errors, invalid phone number or if the number is off, or the message has expired (a message expires if it is not delivered within a period of 24 hours).
You may try to resend the message that has failed to be sent.
Thank you for using Fixya,
Kenneth
2answers
Cannot send text messages!!PLS.HELP...:(
Friend, QUEUED means pending or hanging. There is pending message of yours to be sent. Pending may cause when there is no enough memory to process your data so you need to free up your memory through deleting the unneccesary files. or pending when there is a problem in your network connections.contact your network provider for this case. Good luck
How can I tell if a message is delivered or still pending
usually if the phone says it was sent then it should have been delivered. but if you are in an area with a bad signal then it might say that it was sent at a certain time but not received by who you sent it to for hours or it might not make it at all. that also works visa versa if the party intended is in a weak signal area. you can check to see how fast it sends by texting yourself.
2answers
Message pending
I get this problem a lot. Try turning your phone off, taking the battery and sim out and leaving it for a good few hours. It usually fixes the problem temporarily for me.
May 23, 2008 • Cell Phones
29helpful
4answers
Message sending failed
Reason of this Problem:
Actually it happens due to mem full in Sent Items with Pending Status.
Solution:
Just delete one message from Sent Items.
Better if you delete all messages from your Sent Items, as you will face again this problem if again Sent Items fulls with messages having status Pending.
Regards,
Shakir Idrees
Android Huawei Logo
Top Android Cell Phones Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Sweetleaf
Steve Sweetleaf
Are you an Android Cell Phone Expert? Answer questions, earn points and help others
