SOURCE: radio cuts out but can not hear caller or them hear me
it sounds like a fault with the mic, mabe it is trapped or not plugged in properly. get your engineer back to sort it, they should have fully tested it before leaving.
SOURCE: Parrot CK3100 won't import Contact list from Nokia 6210 Navigator
Try this.
* To send several contacts at once:
* On the phone go to MENU / CONTACTS
* Select a contact to send by pressing OPTIONS / MARK-UNMARK / MARK
* Select your contacts to send then select OPTIONS / SEND BUSINESS CARD / VIA BLUETOOTH / MORE DEVICES
* The phone will search for available devices
* Select the CK3100 from the list and the contacts are sent to your car kit
SOURCE: cannot pair up n95 with parrot ck3100
you willhave to send the contact manually to the parrot you can try making all but if this dont work you will have to send them one by one.
SOURCE: we have been able to
kindly check the compatibility of your phone with parrot. you may check from here. also, installation matters. a professional should be consulted on linking the audio to car speakers and mouth piece mounting and positioning.
Regards
