20 Most Recent Parrot SA Parrot MKi9200 Advanced Color Display Bluetooth HandsFree Car Kit Questions & Answers
Bluetooth not playing music
on your phone or whatever you are using will need to go to settings>bluetooth and allow it to send audio
7/28/2014 12:32:29 AM • Parrot SA Parrot... • Answered on Jul 28, 2014
I installed an mki9200 into a 2007 ford expedition but it seems to not get any power at all I am using a plug and play harness i don't know why it's not getting power
Not all vehicles have a ignition supply at the radio as they use the canbus system to turn things off and on. You will need a multi meter to check if there is power on the correct wires and you my need to pick up the ignition from the fuse box. Parrot web site has details of the accredited engineers in your area.
4/21/2013 8:46:33 PM • Parrot SA Parrot... • Answered on Apr 21, 2013
I have a MKi9200 just updated to the latest
HiI have a a Parrot Mki9200, I did an update via USB and since then the whole unit hasnt turned on when the ignition is on.Can you help?
4/20/2013 11:26:11 AM • Parrot SA Parrot... • Answered on Apr 20, 2013
My parrot mki9200 does not
I had the same problem. stopped turning on one fine day after a little more than a week of installing. then started working again after a few months. realized that it turned on when i thought i had lost it for good. then i also realized that the other instruments in my car were reset, like clock, radio etc. then realized that someone had removed the batteries and installed it again. the clocks restart when you do that. then i realized thats what must've worked and i was right. keeps 'not turning on' from time to time nowadays as well. but works every time i disconnect the batteries and connect them again. like restarting it. hope it works for you too...
1/16/2013 10:44:56 AM • Parrot SA Parrot... • Answered on Jan 16, 2013
Voice control dialling on parrot mki 9200
Most of these devices have problems with accents, noise or names that aren't common. Maybe it is a problem with your device, you can try it indoors and when it still doesn't work correctly, get a refund if you can
1/6/2013 12:53:30 AM • Parrot SA Parrot... • Answered on Jan 06, 2013
0answers
Parrot mki9200 screen not displaying correctly
Hi Mark, I suggest contacting manufacturer by snail mail. When you do so, your problem won't end up in a spam folder, unseen by those who can rectify problem. Worth a stamp because good chance manufacturer will actually respond by sending you brand new product free of charge. Many don't want to go through this "trouble" ; however, businesses are quite competitive (more than you may think!). No business that makes millions wants to lose a good customer + his/her family members & friends for a "drop in the bucket" money amount in order to keep you and other customers. Jimmy
4/7/2012 9:40:00 PM • Parrot SA Parrot... • Answered on Apr 07, 2012
When someone calls me. Both MKI9200 and my phone
You will need to set up an in-car profile in the phone menu then change the ring option to off.
11/13/2011 6:39:11 PM • Parrot SA Parrot... • Answered on Nov 13, 2011
0answers
Hi. I hace just bought
Hi, speakers are poor in design to begin with, these speakers have a low end response of which is ridiculously low for a speaker of this design/size. It's not intended to be a deep bass speaker, most likely what your getting is a result of poor cone construction simply because it's not made for the application your trying to use it for. As a quick fix, you could try putting baffles on them for under $10 bucks. You'll be able to get more response out of them, therefore you can turn the bass down & possibly utilize the speaker more efficiently.
And also do a general troubleshooting That will help...
4/29/2011 10:36:53 AM • Parrot SA Parrot... • Answered on Apr 29, 2011
I am about to buy an MKi9200 to pair with my
The latest software from Parrot and Apple have everything working great now.
2/4/2011 7:10:27 AM • Parrot SA Parrot... • Answered on Feb 04, 2011
I had a paper jam in this model: DM72C and I cleaned all the paper out but it won't start shredding again even though all the power lights are on and ready. What am I missing?
You were asked questions? I have been campaigning for this for 3 months. I told them you need a pop-up All questions need 'make model (what it is)' as first 3 words. You are missing the maker, but you do mention 'shredding'. Then I also said 'There are 40,000 categories to choose from'. You chose 'Cell Phones'. and it's not a 'memo', it's a question. :>) So, first of all, disconnect it from the mains for 30 minutes. If you jammed it, you were working it hard, and when it jams, heat builds up in the motor and trips the thermal protection device. They have a thermal cut out, some have a thermal fuse what need physically replacing, but most reset when they cool. Does it work in reverse? A jam can sometimes damage the switch in the throat of the shredder, some are a mechanical switch, some are an infra-red sensor. https://www.google.com/search?q=DM72C ..
4/24/2024 12:12:23 AM • Cell Phones • Answered 8 hours ago
Parrot SA Parrot MKi9200 Advanced Color Display Bluetooth HandsFree Car Kit Logo
33 questions posted
Top Parrot SA Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
Are you a Parrot SA Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
  • Parrot SA Cell Phones
Most Popular Question
bluetooth not playing music
  • Cell Phones
