Magnetron or the High voltage transformer is faulty
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
SOURCE: Microwave not heating food
check the protector connected at the capacitor and at the magnetron coil windings, check using an ohm meter.,meter should read to zero
SOURCE: Microwave won't heat
The two possible causes are a faulty door switch and a bad magnatron. You can pull the top cover off of the unit and check all of the door switches (there are 2-6 of them all on a common rail, me normally closed)). If the door switches all check out, replace the magnatron, diodes, and capacitor
SOURCE: The microwave stopped heating the food. Power
The light inside the micro wave needs to be replaced most have a door on the back side that yo can remove the screw and unscrew the bulb and take to a applince shop and purchance a new one to replace.
SOURCE: Microwave works except not heating food
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
djh
SOURCE: microwave does not heat
Basic Microwave Oven TroubleshootingTips
heatman101p[]][p
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
heatman101
