he upside down "F" error code on a Frigidaire refrigerator typically indicates a fault with the freezer fan. The fan is responsible for circulating air throughout the freezer compartment, so if it's not working properly, it can cause the temperature to rise and trigger the error code.
Here are a few steps you can try to resolve the issue:
- Check the fan blade for any obstructions, such as ice or debris. If there is something blocking the fan, remove it.
- Make sure the fan blades can spin freely. If they are obstructed or damaged, the fan may not be able to circulate air properly.
- Check the fan motor and its wiring for any damage or loose connections. If you find any issues, contact a professional for repair.
- If the fan motor appears to be working fine, the control board or the temperature sensor may be the cause of the problem. In this case, it is recommended to contact a professional for repair.
If the problem persists after trying these steps, I would recommend contacting a professional for further assistance.
