I BOUGHT A USED ONKYO TX-SR601 ,WHEN CONNECTED SPEAKERS AND MAIN, I ON THE UNIT . IT SHOWS THE DISPLAY AND EVEN THE HEAT SINK WARMS BUT NO SOUND, I TRIED TO RESET BUT DIDNT WORK.
There is a Onkyo recall or service program being offered. I'm not sure if your unit is included, but here is a site to check the serial number to see if it's qualified:
https://repair.onkyousa.com/na
This is posting on the AVS Forum board :
http://www.avsforum.com/forum/90-receivers-amps-processors/1652514-onkyo-acknowledges-failed-units-extending-warrranties-until-2018-a.html
SOURCE: no surround sound
So your saying that you have no rear channel. Some recivers use a single stereo output ic for both sides on the rear speakers. you could have a defect with this IC . Anther thing Im sure you check3ed the obvious ie : the switch is on suround sound? If there is a front to rear fader is it in the middle? Good Luck
SOURCE: Onkyo TX-SR500 Dolby Digital problem
I just read over the problem you were having with your Onkyo TX-SR500 receiver. It sound like the unit needs to be setup for all five channels.Sence your symptom says the diplay shows Dolby D3/2.1. According to the owners manual with the remote control look for speaker setup whin the button is pressed the current speaker setup will be shown in the display. Press the preset/adjustment<> to change the current setting to five speakers. the listening mode will automatically change according to the number of channels you selected. Hope this helps. Radiotech
SOURCE: No receiver display lights
Hi ripper
The unit has a built in display dimmer, with a button to control the level of brightness from the display both on the remote, and the front panel.Try this
regards
Graeme
"Not available in Zone 2 mode" Setting not allowed because the Zone 2 mode is turned on.
"Zone 2 is not On" Will not work because the Zone 2 has not been turned on.
TURN ZONE 2 ON.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Onkyo-TX-SR601-Receivers-manual/id/365ag212/t/2/
Page 55 shows the prerequisite settings for using the surround back terminals for Zone 2.
Page 60 describes USING Zone 2 and points out that only analog sources can be used with Zone 2. Are you trying to use digital sources? Read the notes regarding REC OUT.
