Model aeq6000es2: the "e05" error code normally indicates that control board may need to be replaced or a stuck relay on the control panel. you can reset the unit by unplugging the dryer power cord for 5 minutes and then reapplying the power. if the problem persists then the control board or the control panel may need to be at fault.
Good Luck & All The Best, Justin McCartney
SOURCE: Error code LOC on frigidaire front load dryer
hold down "OPTION and "SELECT" button at simaltaniously until screen resets. This should work for you.
SOURCE: frigidaire affinity dryer problem
the thermistor in air outlet duct is very common for these. with front panel off find plastic duct from blower at bottom. pull out thermistor and look at inner side. it has triangular shape and if you can see shiny redish color at tip instead of all black then its worn. this causes numerous heat and control issues.
SOURCE: LED display on dryer reads AD???
All this is doing is letting you know that the Auto dry sensors are kicked in and checking to see how dry the clothing is.
SOURCE: my frigidaire affinity front load dryer shows the
AD is a indication of board problems.I would unplug the unit for 20 minutes to see if unit will reset
SOURCE: My Frigidaire Dryer (AEQ6000ES2) won't heat. Did
I am not a repair professional. I am just a 78 year old man who has been making his own repairs for about 50 years. Therefore the dryer ID doesn't mean
anything to me. Over the years, I haven't had much trouble with my dryers. The E56 error code means high motor current. To help you find out why, I suggest you go to www.applianceaid.com where they have very good trouble shooting and repair information on dryers and other appliances. I think you'll find what you need there. You can probably verify the meaning of the error code there. Good luck with it. If I have helped you, please rate my advice on fixya.
