20 Most Recent Frigidaire 5.8 cu. ft. Electric Super Capacity Dryer - GLEQ2152 Questions & Answers
E68 for this model number says in manual that this is for a "button stuck" or held down for more than 30 seconds
ck all your buttons for one that just doesn't "feel right" when its pressed , this one will be your problem
Frigidaire... | Answered on May 15, 2020
Sounds like you have a stuck button. Try removing the panel and putting it back on. Worst case scenario- you may have to replace it. Then you'll have a happy Frigidaire appliance again.
Frigidaire Appliance Repair EZ Fix Appliance Repair Las Vegas
ELECTRICDryer no heat or little heat, or shuts down to fast:
Checkyour venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuityit should showOHMS CLOSED CIRCUIT. If not its defectiveor has a short if its grounding out? Which in turns causes blown fuses or thermostats or
overheating.
The heating elements are located inside the heater ducts. If you think a heating element is faulty, test it with avolt-ohm-multimeter(VOM)set to the RX1 scaleat 20K ohms. Disconnect the leads from the power terminals and clip one probe of the VOM to each terminal. The meter should read about 12. (1200)ohms.If the reading is higherohms, the heater is faulty and should be replaced. Replace a faulty heater with a new one of the same type and electrical rating. A heater connected to a 115-volt line usually has an 8.4-ohm resistance; a heater connected to a 220-volt line usually has 11 ohms resistance.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,OR?you may have a broken centrifugal switch in the motor because this switch activates the motor and the heater as well. supposedto be if the motor does not run, the heater should not heat in order not to createafire but ifthe motor is not running,andthe heater is still heating, then there could be a problem with the motor centrifugal switch that is connected to this interlock switch that should trigger the heater.
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
In somedryer'sthecontrol panel relies on athermistorrather than aCYCLING thermostatto regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when thethermistorindicates that more heat is needed to keep the air temperature constant inside the drumthis is why in some cases the dryer will operate at lower cycles like gentle or low heat but not at higher settings?)
Lastly check your moister sensor.( located inside the dryer door usually) Especially if machine seems to shutdown early and clothesare still wet.
Test with a meterat room temperatureand it should show continuity.
A failed moisture sensor will affect the dryer run timein the automatic moisture sensing cyclebut it will not affect the heatingof the dryer or the timed cycle.Which are reflected by the thermostats.
Read more :
https://www.youtube.com/watch?v=wVTBrGMql7g
http://www.ehow.com/info_12203962_check-dryer-thermistor.
GOD IS So GOOD !!!!AND THAT'S WHY MY ADVICE IS FREE
https://www.youtube.com/watch?v=MMP7BW1lLs4
Frigidaire... | Answered on Mar 28, 2020
CONTACT THE PLACE YOU GOT IT USE WARRANTY WE CAN NOT ASSIST YOU
Frigidaire... | Answered on Feb 26, 2020
Start simple. Check for the basic things that will not let the dryer run. Broken door switch. A loose wire on the door switch...those kinds of things. The same would apply to the start button. R
Frigidaire... | Answered on Nov 11, 2019
in don't know. perhaps the system resets itself. consider unplugging from electrical source. push start open and close.push stop if there is one to push. reconnect to power source.
Frigidaire... | Answered on Oct 29, 2019
AD is not an error code i found this out by goin to the frigidaire web site it just means that the dryer is in auto dry mode.
Frigidaire... | Answered on Sep 19, 2019
https://www.partselect.com/Models/FEQ1442ES1/#Symptoms
click on the wiring link under the
Manuals & Care Guides for FEQ1442ES1
and this will explain how to decipher the flashing lights.
Frigidaire... | Answered on Sep 10, 2019
The code E68 indicates that a button is stuck. Check the buttons by pressing them one by one to find the stuck button.
Frigidaire... | Answered on May 30, 2019
Frigidaire 5.8 cu. ft. Electric Super Capacity Dryer - GLEQ2152 Logo
0 questions posted
Top Frigidaire Dryers Experts
Marvin
Marvin
John Tripp
John Tripp
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
View Most Popular
Frigidaire Dryers
  • Frigidaire Dryers
Most Popular Question
fix frigidaire dryer e40 code new dryer
  • Dryers
