Locks & Locksmithing Logo
Nancy Sommers Posted on Dec 25, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
KARA ILCO FRONT DESK UNIT 780 SAYS READER ERROR OR INVALID CARD, CAN THIS BE CLEARED BY RESETTING?
IT LOST POWER, ONCE IT WAS HOOKED BACK UP IT SAID READER ERROR
Claude Kayser
Level 3:
Top Expert:
  • Master 9,098 Answers
  • Posted on Dec 26, 2015
Claude Kayser
Master
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5067947
Points
28436
We have 2 front desk units Kaba ilco 780A1, one of - Fixya
www.fixya.com/.../t4588452-2_front_desk_units_kaba_ilco_780a1_one
Apr 19, 2010 - Question about Simplex Kaba Ilco Unican 1000 keyless lock ... the grand master authorization card is swap it shows a message that says ''reader error or invalid keycard''. .... How to reset grand master keys front desk unit 780.
Hotel Lock - Front Desk Unit - Kaba
www.kaba.co.uk/68244/front-desk-unit.html
Kaba GroupMulti-track keycard encoding and reading; Drop and swipe reader track with ... Front Desk Unit brochures can be found on the Sales and Support page.
Unican front desk unit 780 is not reading any key except grand master. what is the reason we cannot make any guest key
Sounds like someone has deleted or changed other employee I.D. information and disabled their cards.
1helpful
3answers
Is there an SD card slot on the Dell OPTIPLEX 780?
There is no card reader on most models of the Optiplex 780. There may be a card reader on the SFF unit. The MT, desktop and USFF do not include a card reader. You can add a 3.5" internal card reader to the MT or desktop models for under $20. You could use an external USB card reader with any Optiplex 780.
I hope this helps.
Lost GMA Card for Kaba ilco 780 FDU. How can i get another?
When you set up the system, you should have made at least 3 GMA's. Hopefully they did that and there are two other GMA's in a safe place. We keep ours locked up with the other key masters.
If you don't have any GMA's at all, you will have to call KABA. They will give you a reset code to reboot your FDU and then you can make new GMA's. You will have to remake all the other cards as well. It will be like starting over.
Good luck.
LOST CODE AND LATCH WON,T RETRACT WHEN LEVER IS TURNED.
Navigate to this page, which show a grid of Simplex products, then scroll down to the L1000 entry:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13&obj=1000
Then go to the rightmost column (TIPS) and hover your mouse over "PDFs", which will pop up a window with two choices: Changing the code, or How to reset a lost combination.
You will then be able to download a PDF file of your choosing for instructions.
If you don't already have Adobe Reader or another PDF reader program installed on your computer, there is a link at the top of the the grid chart to download Adobe Reader.
Need to know how to re program our kara ilco when i swip the gma card it says card error or wrong card is being used
The Kaba Ilco 1000 lock does not use any sort of card reader for programming--it is strictly a push button lock.
From this link, which you can cut and paste into your web browser:
http://www.kaba-ilco.com/access_control/products/eplex.aspx?id=6
you can search for your model of Kaba Ilco lock and click on the box with the picture of your lock.
This will take you to the page for that particular lock. On the right side of any given page, you will see the heading "Documentation" an under that, a link that says "click here to visit the literature and support page".
Following that link will lead you to a grid of the various lock models, with links to the manuals, etc.
These will be PDF files and will require you to have Adobe Reader installed on your computer to view them. If you don't have Adobe Reader, : http://get.adobe.com/reader/
You will also find a "Contact Us" link on the first link I gave you, where you can contact Kaba Ilco directly for customer and technical assistance.
I hope I've been able to help. Good luck!
Lock failure where can i get these repaired cheap.
You will find a link to download the manual for your model on this page:
Hover your mouse over "PDF" under the "TIPS" column and the two choices of "Changing the Code/Combination" or "How to Reset a Lost or Unknown Combination" will appear--move your mouse over the appropriate one and click to download the info.
These are PDF files, requiring Adobe Reader to open. There is a link on the same page to download Adobe reader, if the file will not display for you.
Good luck--and please provide feedback if this helps!
Customer service can be contacted from this link:
http://www.kaba-ilco.com/access_control/support_contacts/service_and_support.aspx
Tech Support from this link:
http://www.kaba-ilco.com/access_control/support_contacts/technical_support.aspx
2helpful
Lost code
Kaba Ilco has a FAQ document on resetting the code here. If you need more detailed information, your user manual is here.
I'd highly recommend looking at the FAQ. Basically you're going to have to open the unit up, reset the gears so all the slots are lined up facing you, then put the unit back together.
Once you've got everything back together, you turn the outside lever to the stop position, release it, and enter the new combination. Turn the outside lever tot he stop position again, and you're done.
2answers
LaserJet 4350 Printer: HP 4350 printer, 49.2F9D service error...
1st thing to do is upgrade the firmware. Go to hp.com and look for the software and drivers. Drill down to the firmware and read the instructions.
4helpful
Grand master authorization cards expired , can
i really like this article..i just want to appreciate you for this work..and i would like to read more article on this...card master
Top Locks & Locksmithing Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
