Question about Locks & Locksmithing
I have a Defiant Electronic deadbolt from home Depot. model G1X2D01. ive lost the manual and i need to delete some old codes from it.
Model G1X2D01 Purchased from the Home Depot, uses an illuminated keypad for entry.
Posted by john_norton8 on
gagga
Snap off the back cover (opposite where you punch the numbers) by pinching the sides and pulling off. Do not press a pen or anything into the small light, you do not need too. Just pinch and yank off cover. You will see a small light and beside it is a small SET button by the batteries, it is labelled.. Press this Set button for 2 seconds. The red LED will light on the front code side and beep twice to indicate you are in programming mode. Enter your current code that you want to change (factory set is 12345) and then press the button that looks like a little lock on the keypad. Enter the digits "10" and press the lock button again. Enter the new code (must be six digits) and then press the lock button again. The red light should go on continously for 10 seconds. The code should be effective.
Note: if you have problems like we did, you can also remove one battery and press the "set" button simulataneously when you reinsert the battery. This resets the factory code of 12345. Then you can start over. For some reason our old code was only 4 digits, but it would not let us reprogram a 4 digit code. It didn't work until we did a 6 digit new code.
Posted on Aug 13, 2012
Jason Chiu
For this particular Defiant model:
To delete an individual existing user code:
  1. Press SET for 2 seconds. Red light will turn on, beeps twice, and you're now in Programming Mode.
  2. Enter your programming code then press the Lock button (lock "icon").
  3. Enter 30 (3-then-0), then press the Lock button.
  4. Enter the code you wish to delete, then press the Lock button.
  5. Red light stays lit for 10 seconds.
  6. Existing user code is now deleted (you can test to see if the code still works)
To delete ALL existing user codes in one go:
  3. Enter 40 (4-then-0), then press the Lock button.
  4. Press the "C" button for 3 seconds (I think the C stands for Cancel). Green light will turn on with a single beep.
  6. ALL user codes are now deleted (you can test to see if the codes still works).
Add a new user code (in case you're wondering):
  3. Enter 20 (2-then-0), then press the Lock button.
  4. Enter the new user code (4-6 digits), then press the Lock button. Max number of storable codes is 10 according to manual.
  6. New user code is now added (you can test to see if the code works)
Posted on Feb 21, 2013
2 Related Answers
Coaltowner
  • 963 Answers
SOURCE: Schlage Combination deadbolt purchased at Home
Okay, so what's the problem that you're having with the lock. Please try to furnish the model number/ brand of the lockset.
Posted on May 13, 2011
Coaltowner
  • 963 Answers
SOURCE: i have a kwikset deadbolt
I was searched but was unable to find any information on the model 898 keykess entry set.
I therefore suggest that you call Kwikset's Customer Service; I'm sure they can help you:
http://www.kwikset.com/Customer-Support/Contact-Us.aspx
Kwikset Corporation
Consumer Service
19701 DaVinci
Lake Forest, CA 92610
Kwikset Customer Service
Call: 1-800-327-LOCK (5625) Fax: 1-800-713-7080
Support Hours: Monday-Saturday
7:30am-4:00pm PST
Closed Sundays and Major Holidays
Posted on Mar 10, 2011
Lamp is on continuosly, day and night, need to trouble shoot
First, I'm not a Defiant tech.
* Check your warranty. Call for support.
*** following is for information only ***
* May be in "Test" Mode. Check the mode switch.
* Setup Demo; https://www.youtube.com/watch?v=XBaHo_44aps
* Specs on Home Depot; https://www.homedepot.com/p/Defiant-Wall-Pole-Mount-Area-Light-Outdoor-LED-with-Dusk-to-Dawn-Control-DW9519GY-A/207105761
* Please note the question answer section on Home Depot site
Aloha, ukeboy57
Defiant electronic deadbolt manual
I only saw manual mentioned on suspicious or malicious websites/
Sometimes manuals appear for sale on eBay.com or Amazon.com.
Home Depot could be contacted for a manual, as it is their brand name.
Searching for a youtube video might help you.
Example:
https://www.clipzui.com/video/u3q464q2u3z4p4m4162524.html
Electronic Deadbolt Door Lock Install Defiant clipzui com
1helpful
Defiant daylight adjusting digital timer instructions
If you have the Defiant Digital Timer, I found this great video on the Home Depot Website! It's step-by-Step! Nice!! http://www.homedepot.com/p/Defiant-20-Amp-7-Day-7-Event-In-Wall-Digital-Timer-49814/203678179
How to delete codes and enter new codes
take this into home depot they will show you how to do it:) thanks
Locks & Locksmithing Logo
Top Locks & Locksmithing Experts
ray gallant
Tom Chichester
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
