20 Most Recent Master Lock 5400d: Portable Select Access Key Storage Lock Questions & Answers
Hi, Try setting the lock to the original combination and see if it will move then. Also keep a can of spray lube handy (and a rag) to give it a good squirt and free up any rust inside. Good luck.
Master Lock... | Answered on May 08, 2020
Try your old password but push the shackle towards the lock once then put in your old password twice then pull the shackle
Master Lock... | Answered on May 18, 2019
Pull the body of the lock and the U-shaped ring away from each other to put pressure on the mechanism inside the lock. Pull the body of the lock away from its attachment, or, if the lock is not attached, apply pressure on the U-shaped ring away from the body of the lock with your fingers. Keep holding a firm, steady pressure.
Step 2 Roll the dial closest to the U-shaped ring slowly, while keeping steady pressure on the mechanism. The dial will get difficult to roll over three consecutive numbers, and one of those numbers will click. You should feel and hear this small click, and that is the first number to your combination.
Step 3 Repeat Step 2 with the middle dial, and then the farthest dial. Leave the dial set when you find the click, moving onto the next dial. The combination will reveal itself, letting you pull the U-ring away from the body of the lock.
Master Lock... | Answered on Dec 19, 2017
Instructions:
Opening the key storage
compartment door
1. Open shutter door to reveal the dials
and the release button
2. Rotate dials to the current combination
(if the lock is new, the combination is set
at the factory to 0-0-0-0)
3. Press down on the release button
to open the door
4. Pull the door fully open
5. Add or remove keys
6. Close compartment door
7. Scramble the combination dials to lock
the door and conceal your combination (A)
8. Close the shutter door (B)
To set a new combination:
The initial combination is set at the
factory to 0-0-0-0
1. Open the compartment door
(see instructions above)
2. Push the reset lever left and down.
The lever remains in this position
3. Rotate dials to your desired combination
4. Push the reset lever, up and right, back
to the original position
5. Close the key storage compartment door
6. Scramble the combination dials to lock
7. Close the shutter door (B)
To hang shackle model
2. Push the shackle release lever to the left
to open shackle
3. Pull the shackle up and out of the lock
4. Place shackle around door knob or other object
5. Close shackle to lock
6. Close the compartment door
Reminder:
(A) The release button will open the lock
until you scramble the dials
(B) Keep the shutter door closed to increase
weather resistance and to conceal the
dials from view
Master Lock... | Answered on Jul 31, 2017
Have 5400D Master Lock. Know combination, but it will not open. Can someone help me?
Master Lock... | Answered on Aug 11, 2015
Check the MasterLock web site to see if they still offer to provide for forgotten combinations. Some years ago I got a combination for a standard rotary dial lock by providing the usual identification information plus a photo of the lock showing its serial number.
Master Lock... | Answered on Feb 02, 2015
You have 10,000 combinations to go through. Best to cut if off and bring it some place comfortable to try out all of the combinations from 0000 to 9999. Or take it to a machine ship and have someone grind the thing open.
Master Lock... | Answered on Jan 21, 2015
Take your lock if at all possible to a locksmith to avoid any service charges. Don't bother with the manufacturer as they will not give combos out for security reasons. Your lock will have a serial # that your locksmith can access and find out what your combo is. If you can't bring the lock to the locksmith check what their service charge is. It might be cheaper to cut it and replace it than to call the locksmith out.
Master Lock... | Answered on Dec 09, 2014
factory to 0-0-0-0
Master Lock... | Answered on Sep 03, 2014
www.masterlock.com/.../5400D_Instructi...
Master Lock... | Answered on Jul 02, 2014
I HA RASONIC TV MODAL RA-14RNS HE IS DESPLY LOK HO VE UNLOK HAM
Master Lock... | Answered on Apr 12, 2014
RASONIC MODIL RA14RNS UNLOK COD PLZ
Do you mean the studio plus? I don't think there is a super plus, neither is there a child lock but there is a keyboard lock. To remove lock press and hold the hash key, bottom right it should also have a lock symbol on it.
Master Lock... | Answered on Apr 04, 2014
Master Lock 5400d: Portable Select Access Key Storage Lock Logo
200 questions posted
Top Master Lock Locks & Locksmithing Experts
Marvin
Marvin
Lawrence Oravetz
Kelley Hopper
Are you a Master Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
View Most Popular
  • Master Lock Locks & Locksmithing
Most Popular Question
master lock 1534d remember
  • Locks & Locksmithing
