Need to print entire machine layout, how to assemble diagram for the bissell proheat pet upright shampoorer, not the user guide.
First locate screw pack (you will need a Phillips screwdriver). 2 long Phillips screws with hex nuts, 2 short Phillips screws. Should be taped to under part of handle.
2, Put upper handle into lower handle.
3, feed the power cord through the tool caddy from the flat side. Place caddy to handle so the hex shaped holes on upper portion.
4. Place the hex nut in the hex shaped hole and insert long bolt through the front of the handle. Do the same on the other screw and tighten them snuggly. Be careful not to over tighten them.
5. Insert small screws into lower 2 holes through the back side of the lower hose rack. Turn until tightened.
6. Attach tool(s) (that would be a small brush or the pet brush attachment to end of hose and on the attachment holder on front of upper handle.
7. Wrap hose around large holder closest to handle and power cord is wrapped around outer holder with rotating clamp.
Hope that helped
SOURCE: need pics of bissel hose assembly
Just what the doctor ordered:
http://c.managemyhome.com/mmh/answers/Answers.action#l4q145526
This is not my website, you should thank the guy that made this. It took me a few days of searching to find it.
Most likely the pump belt is worn and needs to be replaced. Here is the belt you need:
Bissell Proheat Pump Belt
SOURCE: I need a Bissell Proheat 2x assembly drawing
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
j
SOURCE: I need a guide to tell me the proper way to
Go to www.bbay.dreamhost.com/bissel_proheat_2x_plus this guy took photos as he tookk it apart.
SOURCE: my pet wash bissell shampoor won't pick up the water
Hey Deanne!I know how frustrating it is not having suction when you need it.
Here's a quick link to troubleshooting steps to assist you with the suction.
