SOURCE: 1986 Toyota pickup, Hilux fuel pump
NO the problem most likely is your carb. draining down or accelerator pump not working.
SOURCE: 1994 toyota sr5 pickup not starting due to no
Look in the fuse box under the hood. Look to see if the 15 amp EFI fuse is blown. If so, you may have a short circuit at the fuel pump wiring under the bed/on top of the tank. If it is not blown, you may have an open circuit on the same wire; this is a very common issue to the 94 trucks.
SOURCE: 1991 toyota camry 4 cyl. how to change fuel pump.
I saw this DIY site on how to replace the fuel pump of the 1992 Toyota Camry. This solution can be used in all vehicle types.
http://www.automd.com/62/how-to-replace-a-fuel-pump/
SOURCE: where is the fuel pump
there is not a fuel pump reset. but there is a fuel pump relay toyota calls it a circuit opening relay it is behind the right kick panel above the ECM, power comes from the ECM which gets its power from the ECM main relay.
SOURCE: Need Directions on how to
Here's the fuel pump page from the '93 manual:
http://www.ncttora.com/fsm/1993/engine/28fuelpump.pdf
Chevy Fuel pressure Reliving Procedure
http://schematicsdiagram.blogspot.com/2012/11/chevy-fuel-pressure.html
ECM misfueling Engine?
http://technoanswers.blogspot.in/2012/03/ecm-misfueling-engine.html
Fuel pressure and spark is good but ford escort will not
start?
http://technoanswers.blogspot.in/2012/01/fuel-pressure-and-spark-is-good-but.html
Fuel Running Lean
http://technoanswers.blogspot.com/2012/10/fuel-running-lean.html
How to relieve fuel pressure?
http://technoanswers.blogspot.com/2012/01/how-to-relieve-fuel-pressure.html
Refueling problem?
http://repairhelpcenter.blogspot.com/2012/01/refueling-problem.html
Toyota Tercel consuming more fuel?
http://repairhelpcenter.blogspot.com/2012/01/toyota-tercel-consuming-more-fuel.html
How to maximize fuel economy on your vehicle?
http://schematicsdiagram.blogspot.com/2011/11/how-to-maximize-fuel-economy-on-your.html
After getting car washed, check engine light is ON and key
less entry not working, tried reprogramming. Also car shows fuel pressure?
http://schematicsdiagram.blogspot.com/2011/12/after-getting-car-washedcheck-engine.html
Fuel Injection Problem And RPM suddenly increases
http://whatisbyme.blogspot.in/2012/07/fuel-injection-problem-and-rpm-suddenly.html
2003 Toyota Camry: Fuel not flowing to engine?
http://whatisbyme.blogspot.in/2012/05/2003-toyota-camry-fuel-not-flowing-to.html
How to Replace a Fuel Injector
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-fuel-injector.html
How to Replace a Fuel Pressure Regulator?
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-fuel-pressure-regulator.html
How to Replace a Fuel Pump?
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-fuel-pump.html
HOW TO CLEAN A FUEL SYSTEM
http://schematicsdiagram.blogspot.com/2011/07/how-to-clean-fuel-system.html
HOW TO REPLACE A FUEL TANK
http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-fuel-tank.html
HOW TO REPLACE A FUEL TANK CAP
http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-fuel-tank-cap.html
HOW TO REPLACE A FUEL PUMP ASSEMBLY
http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-fuel-pump-assembly.html
Dodge Dakota stalls, stumbles at idle. Has low fuel flow and
runs hot?
http://schematicsdiagram.blogspot.in/2012/03/dodge-dakota-stallsstumbles-at-idlehas.html
Ford runs lean and idles rough?
http://technoanswers.blogspot.in/2012/02/ford-runs-lean-and-idles-rough.html
Fuel pump relay and cooling fan relay troubleshooting on
1997 ford thunderbird?
http://repairhelpcenter.blogspot.com/2011/10/fuel-pump-relay-and-cooling-fan-relay.html
How to replace Fuel Pressure Regulator?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-fuel-pressure-regulator.html
How to test Fuel Pressure and replace Fuel Pump on Acura Car
models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-test-fuel-pressure-and-replace.html
PGM-FI Main Relay on Acura Car models?
http://repairhelpcenter.blogspot.com/2011/11/pgm-fi-main-relay-on-acura-car-models.html
ALSO FOR,
CAR NO START PROBLEMS:-----
It
can be the issue with weak battery or faulty battery or if battery is ok,then
its faulty starter causing the issue.
From
start to end troubleshooting these problem i suggest you to click the link
below and follow its procedure:-----
What to Do When Car Turns Over But
Won't Start?
http://technoanswers.blogspot.com/2012/11/what-to-do-when-car-turns-over-but-wont.html
Car starting issues?
http://technoanswers.blogspot.in/2012/02/car-starting-issues.html
Car Starting Problems
http://whoisbyme.blogspot.in/2012/06/car-starting-problems.html
1991 Toyota Trecel: Engine Starts fine but
dies when gets Warm?
http://whatisbyme.blogspot.in/2012/05/1991-toyota-trecel-engine-starts-fine.html
1994 Toyota Pickup: Starts fine but dies in
few seconds?
http://howtobyme.blogspot.in/2012/05/1994-toyota-pickup-starts-fine-but-dies.html
1999 Chrysler Cirrus: 8 IGN Fuel Starter Fuse
Blows?
http://whatisbyme.blogspot.in/2012/06/1999-chrysler-cirrus-8-ign-fuel-starter.html
2001 Toyota Camry: No start After replacing Battery?
http://whatisbyme.blogspot.in/2012/05/2001-toyota-camry-no-start-after.html
1989 Toyota Pickup Truck: Turns over but not
start?
http://whatisbyme.blogspot.in/2012/05/1989-toyota-pickup-truck-turns-over-but.html
Car dead and will not Start?
http://whatisbyme.blogspot.in/2012/05/car-dead-and-will-not-start.html
1995 Lexus LS400: Running Hot?
http://whatisbyme.blogspot.in/2012/05/1995-lexus-ls400-running-hot.html
2001 Toyota Prius will not start?
http://whatisbyme.blogspot.in/2012/05/2001-toyota-prius-will-not-start.html
1996 Jeep Grand Cherokee: Engine will not start?
http://repairhelpcenter.blogspot.in/2012/06/1996-jeep-grand-cherokee-engine-will.html
Mitsubishi will not start
http://www.howtorepairguide.com
These will help.
Thanks.
